Transformer output indepedent of core permeability
The discussion centers on the misconception that the output voltage of a transformer is influenced by the core's relative permeability (mu). It clarifies that the output voltage is primarily determined by the turns ratio, independent of the core material's permeability. The reasoning presented suggests that induced field strength (H) and magnetic flux density (B) are interrelated, but in an efficient transformer, the primary voltage establishes the flux that the secondary coil experiences. In less efficient transformers, where losses occur, permeability may play a role in affecting output voltage. Ultimately, the relationship between H and B is crucial, with the primary winding generating the flux that the secondary coil utilizes.
rutman
I am having trouble pinning down why the relative permeability of a transformer core will not directly affect the output voltage. In fact the voltage is determined by the turns ratio and is independent of mu of core material.
Given this where is the flaw in the following reasoning:
Induced field strength H is proportional to current in primary coil, H=k I (to be exact , integral H*dl = If+dD/dt)
Magnetic flux density in core is B=mu H
Voltage in single turn of secondary is proportional to rate of change of B; V=A dB/dt = A mu dH/dt = A mu k dI/dt
From this (apparently specious) reasoning, output voltage depends on mu.
It's because, in the normal way one uses a transformer, H decreases as µ increases, to keep B constant.
The point is that the primary winding sees B and the flux just as the secondary does. In a good transformer, the primary voltage makes the flux, with very little losses, and the secondary sees the same flux - except that they multiply it by their own numbers of turns.
Now if you have a very bad transformer which is inefficient at producing B and loses most primary voltage in the resistance of its copper windings, then H would be more constant than B, and µ would increase B and the secondary voltage.
thanks that rings true. it opens the question why I am setting B instead of H; I've seen maxwell equation formulations with D, H instead of E, B but I suppose what you are saying is that the E,B form is 'basic' and the D,H forms are 'dependent' theron.
ie when i run current thru a wire i determine B, and if i bring a piece of iron or such near, the H is dependent on the extant B and mu of the material
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
