Transforming Equations for the Simple Harmonic Oscillator
  • Thread starter Thread starter noranne
noranne
I guess this is maybe more algebra than calculus, but it stems from a calculus problem, so I'll stick it here.
The problem is:
In the case of the simple harmonic oscillator the solution [to the EOM] may be written at least 3 ways
x(t) = Acos(wt) + Bsin(wt)
= Ccos(wt + del)
= De^(iwt) + Ee^(1wt)
Express C and del in terms of A and B. Express D and E in terms of A and B.
What I've got:
I got the first part, C and del, but I can't figure out how to find D and E. It seems relatively straightforward, I put the A/B eq as the LHS and the D/E eq on the RHS and just applied Euler's Formula to the D term. But I can't figure out how to get the E term in terms of cos and sin.
Any help please?
Hint: A constant that has the imaginary unit in it is still a constant.
Yes, I know, but that still doesn't help me get E*e^(wt) in terms of cos and sin.
D*exp(iwt)+E*exp(wt) is NOT a solution to a simple harmonic oscillator problem in the region of the universe I'm used to. Are you sure you don't mean D*exp(iwt)+E*exp(-iwt)? You certainly can decompose exp(wt) into sin and cos. It's exp(wt)=exp(i(wt/i))=cos(wt/i)+i*sin(wt/i). But if w and t are real, those sin and cos aren't the oscillatory functions you'd expect.
Yeah, one of my friends just told me "Didn't you get Prof's email? That's a typo!"
Gr. I KNEW that I wasn't doing it wrong.
Thanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
