Translating scalar torque quantities to their vector analogues (RE: Dipoles)
The discussion centers on the relationship between scalar torque and its vector representation in the context of a dipole in a uniform electric field. The torque applied to the dipole is expressed as τ = 2.q.a.E.sin(-θ), indicating a restoring torque due to the negative sign. In vector form, this torque is represented as τ = p x E, where p is the dipole moment. The question raised is about the absence of the negative sign in the vector equation and what accounts for it. The restoring nature of the torque is emphasized, as it acts to reduce the angle θ and restore equilibrium.
Jonnie79
My question is at the bottom of this post
PREAMBLE:
If a dipole is turned by an angle θ (in a uniform electric field) then the torque applied on the dipole by the electric field will be:
τ = 2.q.a.E.sin(-θ) = -2.q.a.E.sin(θ)
with the negative sign referring to it being a "restoring" torque. This negative sign is important in:
-dU = ∫τ.dθ = -2.q.a.E.∫sin(θ).dθ
IN TERMS OF VECTORS:
In τ = p x E
p = 2.q.a (in the direction of a), and
E.sin(θ) is the "x E" part of τ = p x E
MY QUESTION:
Where is the negative sign gone in the vector equation? what accounts for it?
I have this now. (I omitted a negative sign)
If I rotate the dipole by θ from equilibrium then I've applied a torque:
τ = p x E, or
τ = 2qa.E.sin(θ)
The restoring torque due to the (uniform) electric field will be to reduce θ (and thus restore equilibrium)
τ = 2qa.E.sin(-θ) = -2qa.E.sin(θ), or
τ = -p x E
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
