Trapezoidal Rule (just need to check my answer)
  • Thread starter Thread starter DivGradCurl
The discussion focuses on using the Trapezoidal Rule with n=10 to approximate the integral of cos(πx) from 0 to 20, which yields a result of 20, while the actual value is 0. The discrepancy is attributed to the low value of n, as a higher n is necessary for accuracy, specifically n ≥ 82 for one decimal place. Additionally, the oscillatory nature of the integrand necessitates a higher sampling frequency to avoid inaccuracies. The conversation emphasizes the importance of selecting an appropriate n to improve approximation results in numerical integration.
DivGradCurl
Problem
Use the Trapezoidal Rule with n=10 to approximate
\int _0 ^{20} \cos ( \pi x) \: dx
Compare your result to the actual value. Can you explain the discrepancy?
My work
The actual value can be found as follows
\int _0 ^{20} \cos ( \pi x) \: dx = \left. \frac{\sin ( \pi x)}{\pi} \right] _{x=20} - \left. \frac{\sin ( \pi x)}{\pi} \right] _{x=0} = 0
Next, we have the Trapezoidal Rule with n=10
T_{10} = \left( \frac{20-0}{10\cdot 2} \right) \left[ \cos (0\cdot \pi) + 2\cos (2\cdot \pi) + 2\cos (4\cdot \pi) + \dots + 2\cos (16\cdot \pi) + 2\cos (18\cdot \pi) + \cos (20\cdot \pi) \right] = 20
Can I just say that the reason for the discrepancy is the low value of n ? According to the error bound, we have
\left| E_T \right| \leq \frac{K(b-a)^3}{12n^2} < \left| \mbox{ error } \right| \Longrightarrow \frac{1\cdot (20-0)^3}{12 n^2} < 10^{-1} \Rightarrow n \geq 82
which shows that in order to achieve accuracy to within one decimal place, it is required to have n \geq 82.
Is that it?
Thank you
PS: I should have calculated that for the first digit...
\left| E_T \right| \leq \frac{K(b-a)^3}{12n^2} < \left| \mbox{ error } \right| \Longrightarrow \frac{1\cdot (20-0)^3}{12 n^2} < 10^{0} \Rightarrow n \geq 26
Can I also say that the need for a higher value of n is due to the oscillatory integrand?
Thanks
Thanks
I think yes, you can.
I do not remember the name of theorem concerning transfer of information which says that the sampling frequency should be at least twice that of the highest-frequency Fourier component of the signal to be transmitted.
Your sampling frequency here is the same as the frequency of the function. It is the worst choice possible as it gives the same values at each point, like a constant function would do.
ehild
