How Do Phase Shifts Affect Resultant Wave Amplitude and Frequency?
  • Thread starter Thread starter Husker70
    Sinusoidal Waves
The discussion centers on determining the amplitude and frequency of two sinusoidal waves that are out of phase. The amplitude of the resultant wave is calculated using the formula A = (2A cos Phi/2), leading to an initial estimate of approximately 10m. However, there is a suggestion to check the calculator settings, specifically ensuring it is in radians mode for accurate calculations. The phase shift is confirmed to be 0.250, but there is some confusion regarding whether it should be "-0.250y" or just "-0.250" in the wave function. Overall, the key focus is on correctly applying the phase shift to find the resultant wave's characteristics.
Husker70
Two traveling sinusoidal waves are described by the wave functions
y1 = (5.00m) sin[pie(4.00x - 1 200t)]
y2 = (5.00m) sin[pie(4.00x - 1 200t -0.250y)]
where x, y1, and y2 are in meters and t is in seconds.
(a) What s the amplitude of the resultant wave?
(b) What is the frequency of the resultant wave?
y = (2Acos Phi/2) sin(kx- wt + Phi/2)
The two waves are out of phase by 0.250
therefore A = (2A cos Phi/2)
I get the Amplitude to be 9.99 or 10m
from 2 (5.00m) .25/2
Do I need to do more for this? I know the answer but can't get there
Thanks,
Kevin
Is it "-0.250y" or just "-0.250" for the phase in y2?
It should be slightly lower. Was your calculator in radians mode when you calculated cos(0.25)?
Thanks,
Kevin
