Triangle that has the hypo as √(u^2 +1)
  • Thread starter Thread starter Jbreezy
    Triangle
Jbreezy
If I have a triangle that has the hypo as √(u^2 +1)
adj as 1 and oppo as u
I did an integral with trig sub. So I used
u = tan(θ)
At the end of my integral I ended up with an expression (1/4)sin(2θ)
When I substitute back into the integral for theta. I will get (1/2)(u/(sqrt(u^2 +1))
right? How does back sub work if you have 2(theta)
Use ##\sin 2\theta = 2 \sin \theta \cos \theta##. You need the trig functions in terms of ##\theta##, not ##2\theta##.
Always like this? With double angle?
Could you please use complete sentences? I'm not sure what you're asking.
Nevermind thx
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
