Trig Identity: Solving \frac{\cos^2 \theta}{1 + \sin^2 \theta} = \sin \theta
  • Thread starter Thread starter cscott
    Identity Trig
The discussion centers around the equation \(\frac{\cos^2 \theta}{1 + \sin^2 \theta} = \sin \theta\), which is ultimately determined not to be an identity. Participants tested specific values, such as \(\theta = -\pi/2\) and \(\theta = 3\pi/2\), revealing discrepancies between the left-hand side and right-hand side. Further exploration led to the discovery of different functions rather than an identity, with expressions involving secant and tangent functions being analyzed. Participants shared methods for simplifying and manipulating the equations, highlighting the importance of verifying identities before extensive calculations. The conversation emphasizes the necessity of checking the validity of trigonometric identities.
cscott
1 - \frac{\cos^2 \theta}{1 + \sin^2 \theta} = \sin \theta
I can only get to \frac{2\sin^2 \theta}{1 + \sin^2 \theta} and I don't know if that's correct.
Perhaps you should check the problem again because it doesn't seem correct to me. Try \theta = 3\pi /2, the LHS will be 1 while the RHS is -1.
It's not an identity!
Let θ = -π/2
then lhs = 1 - cos²(-π/2)/(1 + sin²(-π/2))
lhs = 1 - 0/2
lhs = 1
but rhs = sin(-π/2) = -sin(π/2) = -1
rhs = - 1
Since lhs ≠ rhs, it can't be an identity.
OMG, I've spent so much time trying to figure it out... I never thought of checking to make sure it was indeed an identity. I guess my teacher made a mistake. Thanks guys.
(Don't worry, I'll be back with another too soon :-p)
I did a quick check to see if it was an identity. After all , you were having trouble !
It checked out ok for θ = 0 and θ = pi/2, so I did some work on it.
It was only later on that I plugged the expressions into graphmatica and found out they were actually two different functions !
\frac{1 - \sin \theta}{\cos \theta} + \frac{\cos \theta}{1 - \sin \theta} = 2 \sec \theta
\frac{1 - \sin \theta}{1 + \sin \theta} = (\sec \theta - \tan \theta)^2
I can't seem to get anywhere with these...
For the 1st one, cross-multiply the two terms in the lhs and simplify.
For the 2nd one, multiply the lhs by (1 - sinθ) and simplify.
I can only get to 2 \sin \theta + 2 \sin^2 \theta for the first after cross multiplying.
For the second, how can I just multiply by (1 - \sin \theta)? I thought you can only multiply by 1?
\frac{1 - \sin \theta}{\cos \theta} + \frac{\cos \theta}{1 - \sin \theta}=\frac{1 - \sin \theta}{\cos \theta}+\frac{1+\sin\theta}{1+\sin\theta}\frac{\cos\theta}{1-\sin\theta}=\frac{1 - \sin \theta}{\cos \theta} +\frac{1+\sin\theta}{\cos\theta}=\frac{2}{\cos\theta}=2sec\theta
\frac{1 - \sin \theta}{1 + \sin \theta} =\frac{1-\sin\theta}{1-\sin\theta}\frac{1-\sin\theta}{1+\sin\theta}=\frac{(1-\sin\theta)^{2}}{\cos^{2}\theta}=(sec\theta-tan\theta)^{2}
I see, thanks.
Ah, sorry, that should have been, multiply above and below by (1 - sinθ)
