Trig Integral Question: Solving \intsin32x dx | Tips & Tricks for Calculus
  • Thread starter Thread starter AzMaphysics
    Integral Trig
AzMaphysics
\intsin32x dx
2. The attempt at a solution
\intsin32x dx =
\int(1-cos22x)sin2x dx =
(-1/2)\int(1-cos22x)-2sin2x dx =
(-1/2)\int(1-u2)du where u= cos2x
(-1/2)(u-(u3/3)) =
(-cos 2x/2)+(cos32x/6) + C
Book says (cos3x/3)-(cosx/2) + C
Where did I go wrong?
It looks like you have the right idea, but you should split the integral into two separate integrals after this step:
\int (1-cos^22x)sin2x dx
Yea integrating by parts seems to be the preferred way to attack these types of problems. The chapter was focusing on u-substitution though so I tried going with that. I just can't tell if I made a mistake or if the book did (there's been a couple times in the past) or if the book's answer is just more simplified and I'm not seeing how.
Well I actually checked your work instead of assuming you made a mistake, and you made no mistakes (I got the same thing). The way to do this is definitely a u-substitution and you don't want to split it up as mentioned. Your answer is correct.
To save work, I also computed the derivative of our answer with Maple and it gave me the integrand that we started with. I did the same for the book's "answer", and it did not. So it looks like the book is incorrect on this one.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
