Trouble remembering integration
  • Thread starter Thread starter LocationX
    Integration
The discussion centers on the integration of the function cos(60πx), confirming that the indefinite integral is sin(60πx)/(60π) plus a constant. Participants emphasize that integration is the inverse of differentiation, making it easier to remember if one understands the derivatives of sine and cosine. A substitution rule is highlighted to simplify the integration process. Verification through differentiation is encouraged to reinforce understanding. Mastery of these concepts can enhance confidence in solving similar integration problems.
LocationX
Hi, I'm having trouble remembering integration...
\int cos(60 \pi x)
this becomes... sin(60 pi x)/60 pi?
Yes, that's correct... plus a constant if you're looking for the indefinite integral.
Basically, if you remember derivation, there is nothing to remember about integration except that it is the inverse of derivation. If you doubt that the integral of cos(60x) is sin(60x)/60, just verify that the derivative of sin(60x)/60 is cos(60x).
integration of cos...
Yes it's ok. Remember how to derive sin and cos and it will surely be easier for you
Just remember that nice substitution rule...
\int {\cos \left( {60\pi x} \right)dx} = \frac{1}{{60\pi }}\int {\cos \left( 60\pi x \right)d\left( {60\pi x} \right)} = \boxed{\frac{{\sin \left( {60\pi x} \right)}}{{60\pi }} + C}
...and check via derivative (chain rule here) :smile:
\frac{d}{{dx}}\left[ {\frac{{\sin \left( {60\pi x} \right)}}{{60\pi }} + C} \right] = \frac{{\cos \left( {60\pi x} \right) \cdot 60\pi }}{{60\pi }} = \cos \left( {60\pi x} \right)
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
