Calculators Troubleshooting ERR:SYNTAX on TI-83+ with asm programming
  • Thread starter Thread starter Schwazz
    Programming Ti-83
The discussion revolves around troubleshooting the ERR:SYNTAX message encountered when trying to run an assembly (asm) program on a TI-83+ calculator. The user successfully transferred the program but is confused by the syntax error pointing to the "9" in the command "Send(9prgmNAME". It is clarified that the syntax for running asm programs differs between the TI-83 and TI-83+, and the user likely compiled their program for the wrong model. To resolve the issue, they need to use a TI-83+ compatible compiler and ensure the correct file format (.8xp for TI-83+). Additional advice includes caution with asm programming due to potential freezes or malfunctions.
Schwazz
I've been trying to learn asm for the TI-83+ for the last month or so. I've read a bunch of tutorials, and at some point they all say to send the program to the calculator and then type "Send(9prgmNAME" (in my case, TEST) in either the home screen or a new BASIC program to run it. I had no problem getting the program onto the calculator, but whenever I try to run it an ERR:SYNTAX message pops up and points to the "9". I have no clue what I did wrong. Could someone help me?
If it makes finding an answer easier, here's the code:
.NOLIST
#define equ .equ
#define EQU .equ
#define end .end
#include "ti83asm.inc"
#include "tokens.inc"
.LIST
.org 9327h
ld a, 3
ld b, 6
add a,b
call _setxxop1
call _stox
ret
.end
END
Computer science news on Phys.org
I've haven't programmed with ASM in a long time, but here goes. I think with the TI-83 it has a built in asm interpreter. Press 2nd + Catalog and it will bring up a list of commands. scroll down to something like "asm(" or "asmprg(". Try those commands.
Code:
asm(<program name>)
Oh, and be careful with ASM. although you can rarely break your calculator with it you can put it out of service for about a day. You can get some very bad freezes.
-HBar
Figure it out?
If you didn't figure it out yet, I think Patrick Davidson has something about this problem in his FAQ. You can find this on his website at http://pad.calc.org/.
asm blues
All the syntax for sen(9"program name") is only for the ti-83. It does not work the same on the ti-83+. Chances are if that is what you learned in a tutorial you have compiled the program for the ti-83. You need to find a ti-83+ compiler. I just started to get my asm programs to work and if u need to know where i got my compilier e-mail me at moo_cow0486@yahoo.com and I can try and find it again. The files for a 83 plus are different from an 83. 83+ files are called prgmname.8xp 83 files are prgmname.83p the 83 files won't work on the 83+.So if you have any probs e-mail me or I am me at MooCow04862004 on AOL IM.
While we are on the topic of TI calc programming.. I am new to the downloading of software from the Internet from my TI-86.. I am totally lost on how to even start d/ling! I received a CD with the connector..Anyone help me please! Thanks :P
First install the TI connect software. Next go to any site with calculator programs such as http://www.ticalc.org and download the programs you want. Connect your calculator to your computer using the graph link you hopefully have if you are asking this question. If you are using TI connect open up the calculator explorer and drop the programs you downloaded from my computer to the calc explorer.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
9K
9K
10K
9K
16K
