Tube Strength charactoristics
  • Thread starter Thread starter pharllap
    Strength Tube
To determine the load-bearing strength difference between a hollow tube and a solid tube with a uniform cross-section, one should calculate the sectional modulus for both designs. The stress induced in each tube can be assessed using the formula σ = M/Z, where σ is the stress, M is the applied moment, and Z is the section modulus. While compression strength may be similar for both types, the load-bearing capacity along the length of the tube is expected to differ significantly. The weakest point is likely where the cross-section is smallest, particularly in the hollow tube, and stress concentrations may occur at sharp corners. Understanding these factors is crucial for effective design in applications like space frame chassis for vehicles.
pharllap
How would i work out the load baring strength difference between a hollow tube and a tube, with a x section throughout the length?(as per thread bellow)
http://i323.photobucket.com/albums/nn463/pharllap/endview.jpg
I love designing things and in this case I'm asking in respect to space frame chassis for vehicle.
Strength is broad question and thinking compression strength form the end be similar to hollow, however load baring strength along the length I'm thinking should be a substantial difference..
Any help greatly appreciated
Regards Phil(Perth, OZ)
by calculating the sectional modulus for both cross sections
σ = M/Z
σ = stress induced
M = Moment applied
Z = section modulus
what you want to ask is how the stress varies along the axis of the vessel. I think the weakest part will occur where you have the smallest X-section, like in the hollow part. However, stress concentration at sharp corners in the transverse cross-section may also exist.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
