homerwho
- 42
- 17
- TL;DR Summary
- I had an old dial tune TV set. Obsolete now.
It had a small button that I think was suppose to improve reception. What did that button do physically?
Button or dial? It was common to have a "fine tune" dial control on those early sets, since they did not have frequency synthesizers and other ways of making very accurate frequency adjustments.homerwho said:Summary: I had an old dial tune TV set. Obsolete now.
Dial. It had a button that when pressed it would latch. It did have the fine tune knobsberkeman said:Button or dial? It was common to have a "fine tune" dial control on those early sets, since they did not have frequency synthesizers and other ways of making very accurate frequency adjustments.
"Well, which is it young feller?" (Quiz Question -- what movie is that from?)homerwho said:Dial. It had a button that when pressed it would latch. It did have the fine tune knobs
homerwho said:I don’t recognize the quote. But it is humorous.
My guess would be either a fine tune on the frequency, or a change in the AGC range.homerwho said:Well old timer what do you think the change was. It never did didly swat. I’m interested in what it was.
I assume that's a typo, yes? Or is there some part of the country where "diddly squat" is "didly swat" ?homerwho said:It never did didly swat.
It is whatever electromagnetic noise there is at the frequency of the channel. That noise will vary from channel to channel and from one location to another.homerwho said:I have another question. If I tuned that to channel 11 but l don’t have signal. What is displayed. I realize it’s static. But is the static the same channel to all without a broadcast?
So you were receiving VHF signals, channels 2 -13.homerwho said:I have another question. If I tuned that to channel 11 but l don’t have signal. What is displayed. I realize it’s static. But is the static the same channel to all without a broadcast?
Actually, our first color TV back in the 70's had one. It was a momentary contact button, and when you pushed it, the picture would jump and wriggle, as if it was a reflection in a pond you had dropped a pebble into. It would settle down in a couple of seconds, with possibly some change in the color. IIRC, it was supposed to counteract accumulated magnetization of the chassis and picture tube.256bits said:I never knew a television that did have a de-gausser button on the unit, and I have known a few.
As did my first trinitron computer monitor. Not sure its the switch in questionsandy stone said:Actually, our first color TV back in the 70's had one. It was a momentary contact button, and when you pushed it, the picture would jump and wriggle, as if it was a reflection in a pond you had dropped a pebble into. It would settle down in a couple of seconds, with possibly some change in the color. IIRC, it was supposed to counteract accumulated magnetization of the chassis and picture tube.
A picture would help.homerwho said:But it had a three position push button.
A quick Google Images search on Panasonic TV 1980s turns up some possibilities. Here is the CT9010, which does indeed have an AFT button...homerwho said:It was a Panasonic from the 80's.
That's my bad. The link was kind of hidden at the end of my post after the picture.homerwho said:I didn't see the Wiki link.
That is my impression, although I've never designed that particular kind of circuit (I've designed PLLs, which are a related type of circuit though).homerwho said:Is it a tracking function of some kind?
Wikipedia said:In radio equipment, Automatic Frequency Control (AFC), also called Automatic Fine Tuning (AFT), is a method or circuit to automatically keep a resonant circuit tuned to the frequency of an incoming radio signal. It is primarily used in radio receivers to keep the receiver tuned to the frequency of the desired station.
And maybe this is why it didn't seem to do much. If you try to use it to improve the picture right away, that's not what it was for. It was to keep the picture tuned well as you watched the same channel for a while (especially right after you turned the TV on and the tuner circuit wasn't warmed up yet).homerwho said:It never did didly swat
berkeman said:That is my impression, although I've never designed that particular kind of circuit (I've designed PLLs, which are a related type of circuit though).
My impression from the Wikipedia article is that the feature is used to help stabilize the tuner's lock-in to a channel once is is tuned well. It helps to prevent drift of those old tuner circuits with temperature and time as you stay tuned to the same channel. So I'm guessing (somebody find the old manual please?) that you would change the channel knob to the channel you wanted, turn the Fine Tuning knob to get centered on the broadcast signal, and then turn on the AFT/AFC.
As long as the TV was still turned on, that would help to keep the TV tuned right on the frequency of that chosen channel. If you wanted to change channels or if you turned the TV off and later turned it back on, you would need to do the fine-tune knob (with AFC off) again first, and then re-engage AFC. But that's just my educated guess, unless somebody can remember better or find an old TV manual...
My guess, is the button.. bypass or applies the fine tune-if it be auto or knob adjusted...homerwho said:Summary: I had an old dial tune TV set. Obsolete now.
Welcome to the PF.ParagustIS said:My guess, is the button.. bypass or applies the fine tune-if it be auto or knob adjusted...
Sorry i just replied to the first question. I scrolled through the posts. Didnt see anything lf bypass /engage button.. sorry if i missed it. I registered just now as i recognise a gold source. I am still to fill oit my profile.. apologies, i don't get offended.. if I am ever in the wrong. Just tell me... i like to be wrong, it the only possible condition to deliver true learning. No game of ego confirming for me. Shoot me Down at every sight... there's nothing greater. Nice to meet yall, sorry. I know this isn't the right place.. ill go intro in rhe correct section.berkeman said:Welcome to the PF.
Did you read any of the posts in the rest of this thread? Or just the first one...![]()
it was used to set the brightnesshomerwho said:Summary: I had an old dial tune TV set. Obsolete now.
What you said:berkeman said:
berkeman said:As long as the TV was still turned on, that would help to keep the TV tuned right on the frequency of that chosen channel. If you wanted to change channels or if you turned the TV off and later turned it back on, you would need to do the fine-tune knob (with AFC off) again first, and then re-engage AFC. But that's just my educated guess, unless somebody can remember better or find an old TV manual...
This seems to be the why I never used the button. I never heard it mentioned in the manual about tuning and engaging. And tune another while disengaged and reengage.dlgoff said:What you said:
I don’t know but it’s the Dukeberkeman said:"Well, which is it young feller?" (Quiz Question -- what movie is that from?)
The "Improve Reception" control was a fine-tune dial or a single push-button?
it appears soGeorge Jones said:Some the static was quite old, i.e., from 14 billion years ago.
homerwho said:I don’t know but it’s the Duke
it appears so
homerwho said:Summary:: I had an old dial tune TV set. Obsolete now.
This evening I cruised YouTube and watched a show about the Big Bang and it’s plateau after 20 some days. According to the video Cosmic Mictowave Background had begun to appear. In the same show they say that artifacts in the static on those TV sets were sporadic CMB. I was watching on the tv and a did not think to figure out how to share it here. They discussed the noise with artifacts as CMB. Interesting that back then that CMB was included in a BBT discussion. The button had three positions. Thanks.DrClaude said:It is whatever electromagnetic noise there is at the frequency of the channel. That noise will vary from channel to channel and from one location to another.
it appears so
This evening I cruised YouTube and watched a show about the Big Bang and plateau after 20 some days. According to the video Cosmic Mictowave Background had begun to appear. In the same show they say that artifacts in the static were sporadic CMB. I was watching on the tv and a did not think to figure out how to share it here. They discussed the noise with artifacts as CMB. Interesting that back then that CMB was includedDrClaude said:It is whatever electromagnetic noise there is at the frequency of the channel. That noise will vary from channel to channel and from one location to another.
Tom.G said:Interesting video! Too bad it leaves so many things unanswered, even the successful experiments.
Now back to that 'rectangular button' you were asking about. Below is a short video that seems to describe it. But first an overall explanation.
The function indeed appears to be switching the Automatic Frequency Control (AFC) On and Off. The AFC functions by controlling the frequency of the local oscillator in the tuner by applying a variable voltage.
If I recall correctly, the varying voltage was obtained from the Ratio Detector used for the FM audio demodulation. A Ratio Detector has the characteristic of having a plus or minus DC offset output depending on whether the incoming IF signal is above or below its resonant frequency. The audio subcarrier is at 4.5MHz, and if the the tuner is on-frequency the IF will be at 4.5MHz.
If the tuner drifts off-frequency the audio IF will differ from the nominal 4.5MHz, the Ratio Detector will then generate a voltage, which is fed back to the tuner to shift the local oscillator frequency.
I suspect the On-Off button was needed because the tuning could only be shifted a small amount, requiring the user to get close to the correct frequency (correct tuning).
Hope this helps!
Cheers,
Tom
