Agent M27
- 169
A block of mass m1 = 1.6 kg is initially moving to the right with a speed of 4 ms-1 on a frictionless horizontal track and collides with a spring attached to a second block of mass m2 = 2.1 kg initially moving to the left at a speed of 2.5 ms-1. The spring constant is 600 NM-1.
a. Find the velocities of the two blocks after the collision.
(1) m1v1i+m2v2i = m1v1f+m2v2f
(2) v1i - v2i = -(v1f - v2f)
So this is a problem in the book that is worked out for me, but I cannot seem to figure out the reasoning behind the way they combined and manipulated the equations. They first begin by subbing in the known values into EQ (1) which I agree with. They then state to use EQ (2) due to the collision being ellastic, which I don't totally understand this relationship. They sub known values into EQ (2) giving the following:
6.5 ms-1 = -v1f = v2f
The book then states that I must multiply the EQ I gave right above by 1.6 kg which gives me the following which I will label as EQ (3): This is what I don't understand, why would I multiply EQ (2) by 1.6kg?
10.4kgms-1 = (-1.6kg)v1f + (1.6kg)v2f
The book goes on to state that I now must add EQ (1) and EQ (3) which apparently allows me to solve for v2f, but I don't see where the thought process determines that I add these two EQ. Thanks in advance for the assistance, I am hoping this is a relatively simple algebraic procedure that I am missing.
Joe
