Two charged spheres are brought into physical contact with each other.
Two charged spheres with initial charges of 2.34 nC and -3.23 nC are brought into contact, prompting questions about the final charge and electron transfer. The final charge on each sphere after contact should be calculated by averaging the total charge, which is not correctly done in the initial attempt. The discussion highlights confusion over the calculations and the need for clarification on how to determine the number of electrons transferred to achieve charge balance. Participants encourage each other to revisit the problem and consider the relationship between charge in nanocoulombs and the number of electrons. The urgency to understand the concepts before the deadline is evident, emphasizing the importance of grasping the underlying physics.
alittlelost
Two charged spheres are brought into physical contact with each other. Initially, the charge on the first sphere was 2.34 nC, while the charge on the second sphere was -3.23 nC.
a) What is the final charge (in C)on either charge?(2A)
b) How many electrons moved from the more negative object to the more positive object to achieve charge balance? (1I,3A)
for a) I did (2.34)+(-3.23)/2 and got -0.445nC... That can't be ight can it? what am I doing wrong?
didn't even attempt b) ... I'm so lost.
I think you got part a) right. Doesn't that give you courage to try part b)?
I don't even know where to start.. my brain is fried :(
Maybe be better to try tomorrow. It's not that hard. How many electrons in a nC? How many nC were tranferred?
I have to know how to do this by tomorrow... what formula should I be using here? Sorry, this is such a noob question to ask haha.. I'm seriously lost though and my head feels like its about to explode.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
