Calculating Applied Force in a Two-Crate System with a Spring
  • Thread starter PierceJ
  • Tags
    Spring
In summary, two large crates with masses of 575 kg and 255 kg are connected by a stiff, massless spring with a spring constant of 7.8 kN/m. They are propelled along a frictionless, level factory floor by a constant horizontal force applied to the larger crate. The spring compresses 4.7 cm from its equilibrium length. Using the equations F=kx and F=ma, it can be determined that the applied force is 1.19 N.
PierceJ
45
Two large crates, with masses 575 kg and 255 kg, are connected by a stiff, massless spring (k = 7.8 kN/m) and propelled along an essentially frictionless, level factory floor by a constant force applied horizontally to the more massive crate. If the spring compresses 4.7 cm from its equilibrium length, what is the applied force?
F=kx?
F=ma
I started by drawing a picture and setting up some free body diagrams. The question kind of confuses me because it just says horizontally but not which way, but if the spring is being compressed then the bigger block is moving towards the smaller block?
There is a hint in the homework that says there is a non zero acceleration but I don't understand how you can find it?
If the spring is being compressed, then it gets smaller.
This means that the crates get closer together ... so the big crate is being pushed towards the smaller one.
Just go through the free body diagrams ... what are the forces on the big crate?
Mg, the normal force, the applied force, and the force of the spring.
Cool - so can you write Newton's law relations for the forces?
Fapp - Fspring = ma?
You got the directions right anyway. Let's call the +ve direction the direction of the applied force - this is also the direction of the acceleration.
Lets just call the applied force F, avoid subscripts = good, what is the equation for the force in the spring?
(We can also use M for the mass of the big crate and m for the mass of the little one.)
F=kx I believe
Well done - so what is the Newtons law relation for the big crate then?
F-kx=ma?
Sounds bashful, with the question mark...
F - kx = Ma is correct. (I follow Simon's suggestion to call the big one's mass M).
You know the values for k, x, and M, so to find F you need a second equation. There is one given we haven't used yet. Any chance to link it to an unknown with a suitable equation ?
F=ma of the second block?
Again this question mark ..
Now we run the risk of confusion. F was the applied force in Simon's advice in post #6 (I'm not so much against subscripts, but never mind).
m is the mass of the small crate
We assumed that the spring compression is a constant 4.7 cm -- meaning the distance between the crates is constant -- meaning the speed of both crates is the same at all times -- meaning the acceleration of both crates is the same at all times (*)
This means we can use the same a as we used in F - kx = Ma
And we have the force the spring exercises on the small crate, that is: we have an expression for that force in terms of known variables. (Think of Newton's third law)
So force = mass times acceleration can be expressed as an equation with one unknown, namely a: ##\qquad## kx = ma
And now we are in business to work out F.
(*)In fact that is pretty hard to achieve on a completely frictionless floor !
So you use kx=ma to find the acceleration and then plug that into F - ka = ma? I'm afraid I don't fully understand.
a Please stick to the correct notation. M was the big crate m was the small one. You want to eliminate a, so you want to substitute knowns for it.
And there never can be ka to subtract from a force. It doesn't have the dimension of a force.
But basically, yes. You use kx = ma to find the acceleration a and stick that a into F - kx = Ma .
Your notation & typo (I hope) threw me off.
Furthermore it's good practice to keep working with symbols as long as possible, preferably until you have one single answer expression:
  • factors and/or terms may cancel
  • less chance of calculation errors
  • possibility to check dimensions
Oh sorry, I did not realize you had done that. Subscripts are much easier for me to work with, I think.
kx = m2a
a = kx/m2
Then I plug that into the other equation
F - kx = m1(kx/m2)
Is this the right thought process?
Yes, well done.
I'm not getting the correct answer with this, so I'm must be messing up in the algebra somewhere.
F - (7.8 * 0.047) = 575 * ((7.8 * 0.047)/255)
F = 1.19N
Which is not the right answer here.
Edit: nvm, had to convert kN/m, to N/m. Got it now. Thanks a bunch!
Related to Calculating Applied Force in a Two-Crate System with a Spring
1. What is "Two crates and a spring"?
"Two crates and a spring" is a simple physics demonstration that involves two crates being connected by a spring. The crates are placed on a flat surface, and when one crate is pushed, the other one moves as well due to the force of the spring.
2. What is the purpose of this experiment?
The purpose of this experiment is to demonstrate the concept of energy transfer through a spring. When one crate is pushed, it compresses the spring and stores potential energy. This energy is then transferred to the other crate, causing it to move.
3. What factors affect the movement of the crates?
The movement of the crates is affected by the force applied to the crates, the stiffness of the spring, and the mass of the crates. A stronger force or a stiffer spring will result in a greater movement of the crates.
4. How does the spring affect the movement of the crates?
The spring acts as a medium for energy transfer between the two crates. When one crate is pushed, it compresses the spring, storing potential energy. This energy is then transferred to the other crate, causing it to move. The stiffness of the spring also affects the movement, as a stiffer spring will require more force to compress and release the stored energy.
5. What real-life applications does this experiment have?
The concept of energy transfer through a spring is used in many real-life applications, such as shock absorbers in vehicles, pogo sticks, and even trampolines. Understanding this concept can also be applied to more complex systems, such as in engineering and design of machines and structures.
