How Is Charge Calculated in a Two Loop RC Circuit After the Switch Opens?
In summary: It has a value of 180.496 μC.In summary, after the switch is opened, the charge on the capacitor decreases exponentially.
Gee Wiz
137
A circuit is constructed with four resistors, one capacitor, one battery and a switch as shown. The values for the resistors are: R1 = R2 = 22 Ω, R3 = 91 Ω and R4 = 129 Ω. The capacitance is C = 40 μF and the battery voltage is V = 12 V. The positive terminal of the battery is indicated with a + sign.( picture: https://www.smartphysics.com/Content/Media/Images/EM/11/h11_RC_time.png )
After the switch has been closed for a very long time, it is then opened. What is Q(topen), the charge on the capacitor at a time topen = 790 μs after the switch was opened?
Q(t)=Qmax(1-e^(-t/rc))
I found earlier that the Q at infinity is 180.496uC. I assume that would be my Qmax. My t would be 790us. I think I am messing up getting rc. My final answer comes out as negative each time. (clearly not correct)
Gee Wiz said:
1.
I found earlier that the Q at infinity is 180.496uC. QUOTE]
Definitely, your Q at infinity is not 180.496 μC. It's a lot closer to zero ...
No, but it really is. The online homework marked that as correct
the current approaches zero as time goes to infinity, and q approaches it max value as time goes to infinity. Q is zero in the beginning
Gee Wiz, do you think that the charge on the capacitor will increase or decrease over time after the switch opens? What does your Relevant Equation predict?
decrease, because it will be discharging.
i think I'm struggling to find the time constant r*c. I know that c is just the capacitance, so 40e-6F in this case. But is r the total resistance of the circuit, or part of it?
Then consider the curve that your Relevant Equation describes at time increases.
Well, it is exponential. Is that what you're getting at? or am i off the mark?
r is the total resistance that the capacitor "sees"; it is the equivalent resistance that the network presents to the capacitor at the terminals where it is connected. So in this case it is the sum of the series connected resistors.
So, in this case it would be R1 and R2?
Exponential is correct. But should it be exponentially deceasing, or increasing to a maximum plateau? What curve does your Relevant equation describe?
Is there a complete path (a circuit) though R1 and R2 to the capacitor when the switch is open?
Well i believe it would be exponentially decreasing to zero. Because once a capacitor is fully charged (for the circuit that it is in) the current of the through the capacitor is zero. So, any resistor in series with the capacitor would have a net voltage drop of zero. The capacitor has a voltage drop which is calculated v=Q/C. Before the capacitor if fully charged, or rather has no charge t=0, it acts almost like a wire. There is not voltage drop across it, and the current is maxed out.
So what, then, should be the equation describing the charge (or voltage) on the capacitor after the switch is opened?
Well immediately after it would just be C=Q(max)/V...?
Yes, that's the initial condition. But what equation will the charge (or voltage) follow after that?
q(t)=q(max)(1-e^(-t/(r*c)))
Why don't you plot that equation. What shape does it have? Suppose t = 0, what is q(0)?
It has exponential shape (um..yes I am aware that is poor description =/ ). It is increasing rapidly at first and then levels off as it approaches its max value. At t=0 (assuming the switch was open before) q=0
Yes, very good. Now, at t=0 (when the switch opens) is q = 0 and does it then increase to a maximum value?
When you say when the switch opens, was it closed before?
I am following the logic of the problem statement. The switch was closed for a long time, then opened at time t=0.
okay, well it then q would be at its max value and from there would be exponentially decreasing towards 0
Yes, that's right. So what equation would describe that?
isn't it this one q(t)=q(max)(1-e^(-t/(r*c)))?
No. Since ##e^0## is 1, the curve starts from 0 and rises. This is because (1 - 1) = 0.
You want the curve to start with the maximum value and then decay down to zero. So get rid of the "1 - " bit and use just the ##e^{-x}##.
Ahhh, okay. So the formula i gave is when q starts at zero. But, this problem q is starting out maxed out. so, from what you said it would just be q(t)=q(max)(e^(-t/(r*c)))?
Yes. I'm surprised that you didn't know this from your text or notes; surely there must be examples there?
We don't have a textbook for my class. The notes only have the original equation i posted. But, i think i should have been able to deduce this one since the current formula given is I(t)=I(0)(e^(-t/(r*c)))
  • #31
Okay, so for this part (figuring out R for the time constant) do i just include the resistors that are in the new circuit with the capacitor. Let me try to explain, when the switch is open i can basically ignore that wire and everything that feeds off only that wire. So, in this case the battery, R4, and R1. Is that correct logic?
  • #32
Yes. Current can only flow when there is a closed loop.
  • #33
Awesome. Thank you so much. The whole talk through was very helpful, and it was better than just getting the right answer.
  • #34
I'm very happy to have helped :smile:
  • #35
Did we ever come up with the right Qmax across C? Last I saw was Qmax = CV but V is the battery so that equation is incorrect.
