Two objects acceleration problem
  • Thread starter Thread starter MightyDogg
    Acceleration
The problem involves the scenario of a baby bird falling from a height and its mother needing to accelerate downward to catch it. The context is rooted in kinematics, specifically focusing on acceleration and the motion of falling objects.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the time taken for the baby bird to fall a certain distance and subsequently determine the required acceleration of the mother. Some participants question the interpretation of the negative acceleration and whether the problem requires only the magnitude.
The discussion includes verification of calculations and clarification of the sign convention used for acceleration. Participants are exploring the implications of the negative sign in the context of direction and magnitude, with no explicit consensus reached on the final interpretation.
There is mention of the importance of establishing a coordinate system for future problems, indicating a potential area of confusion regarding directionality in kinematic equations.
MightyDogg
A baby bird falls from a nest 18m high. After the bird falls 2 meters its mother realizes and catches it 1.5m off the ground. How fast must its mother accelerated down in order to catch its baby?
[tex]x= \frac{1}{2} a t^2[/tex]
I calculated the time it took the baby bird to fall 2m. It was .638 s. Then I calculated the total it takes for the baby bird to fall 16.5m (1.5m off the ground) and it was 1.835 s. Then I subtracted the two to get the time the mother has to reach its the baby bird. That time was 1.19s. Then I plug it back into the equation with 'x' as 16.5m. I calculate acceleration to equal -23m/s^2.
Is that correct? I think it is, I just want to double check. Any help would be appreciated. Thanks.
Your answer looks correct. I guess the negative sign indicates that the acceleration is downward. It could be that the problem is asking only for the magnitude of the acceleration in which case you could drop the sign. Hard to tell.
I forgot to mention when I put 16.5m into the last equation I made it negative because it was going downward, thus my acceleration turned out negative.
As long as the magnitude is correct then I'm ok with the problem. Thank you for double checking my work.
As you get into more complicated questions, make sure to draw your coordinate system indicating which directions are positive! This can save you lots of heartache in the future, especially with problems relating to force.
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 38 ·
