Two parallel lines with current
The discussion focuses on the forces acting on two parallel wires carrying currents of 3 and 5 amps, separated by 0.2 meters. Participants analyze the direction of the magnetic field around wire #1 and its effect on wire #2, using the right-hand rule to determine the force direction. It is concluded that wire #2 experiences a force due to the magnetic field created by wire #1, with discussions suggesting the force is directed into the page. Newton's third law is referenced, indicating that the forces on both wires are equal and opposite. Overall, the participants seek clarity on the application of the Lorentz force equation and the resulting magnetic interactions.
carrotcake10
http://img294.imageshack.us/img294/3157/lines.gif
Two long parallel wires are separated by 0.2 meters and carry currents of 3 and 5 amps as shown in the figure. What can we say about the force on wire #2?
There is no force on wire #2
The force on wire #2 is towards wire #1
The force on wire #2 is away from wire #1
The force on wire #2 is into the page
The force on #2 is out of the page
There is no force on #2 but there is a torque.
I believe that wire #2 has a stronger force on it, but I don't quite know what direction it would be in. Trying to use the right hand rule, i believe it is in the -k direction, but am unsure. I just for some reason don't feel entirely confident.
Any help is gratefully appreciated!
You must look at the diagram sideways, with the two currents coming right toward your eye. IF it is conventional positive current, use the right hand rule around wire 1 to see which way the magnetic field circles around the wire (counterclockwise). Draw or imagine a series of circular B lines around wire 1, including one that touches wire 2. B is tangent to the circle so it is to the right at I2, which is located below I1. Use the other right hand rule to determine the direction of the force when I is out, B to the right.
The force on wire 2 has to be equal and opposite to the force on wire 1 by Newton's 3rd Law.
Leaving aside that Newtons Laws of action reaction might have something to say about that. that's not a choice.
How would you apply the Lorentz force equation?
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magfor.html#c1
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magcur.html#c1
Both of you thank you for your replies. Delphi, I hadn't though of looking at it that way, but is that just to make it seem easier? I don't really get lost with directions in my head.
Lowly, using a combination of those two links (good info btw), I feel like r = +i, and B = +k, which would cross into -j. Is that right? Am I grasping this concept ok? From the first link, I understand that the field is going into wire 2 from the direction of my wrapped fingers.
Edit: I just figured that since the field from wire 1 would actually come down on top of wire two, causing a resultant in the negative k direction. Would this be right? Does the field spiral away from wire 1?
