How do I find the proper distance between two particles in relativity?
To find the proper distance between two particles in relativity, one must consider the effects of length contraction. Given the particles move at a speed of v = 3/4c and have a time interval of t = 50 ns before hitting a target, the laboratory measures their distance as vt. The proper distance, or rest length, can be calculated using the length contraction formula, which relates the measured length to the proper length. Understanding these concepts is crucial for solving such problems effectively. The discussion emphasizes the importance of grasping the foundational equations in relativity to approach these exercises confidently.
dead1327
Two particles moving in a straight line in a laboratory reference system at a speed v = 3/4c, hit a stationary target with a time interval t = 50 [ns]. Finding the proper distance between the particles before hitting the target.
Show all relevant equations as well as your attempt at a solution.
Not like starting..
What do you mean? That you don't know where to start? If so, do you know the equation for length contraction? You need to find the rest length, and the measured length is just vt because that's how far apart the laboratory believes the particles to be.
I need your help because I do not understand how to start these exercises left me doubt if they can do would be helpful
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
