Two radio antennae radiating in phase
  • Thread starter Thread starter sghaussi
    Phase Radio
Two radio antennas, A and B, radiate in phase, with B positioned X meters to the right of A. The problem involves determining the longest wavelength for destructive interference at point Q, located Y meters to the right of B. The relevant formula is (r2 - r1) = (m + 1/2)λ, where r2 is Y and r1 is Y + X. The discussion clarifies that the longest wavelength occurs when m = 0, leading to the equation λ = 2X. The confusion was resolved when the participant realized they had been entering incorrect values in their calculations.
sghaussi
hii guys! I'm having trouble with a homework and I was wondering if you could explain something to me. Here's the problem:
Two radio antennas A and B radiate in phase. Antenna B is a distance of X meters to the right of antenna A. Consider point Q along the extension of the line connecting the antennas, a horizontal distance of Y meters to the right of antenna B. The frequency, and hence the wavelength, of the emitted waves can be varied.
What is the longest wavelength for which there will be destructive interference at point Q?
I know I want to use the formula: (r2 - r1) = (m + 1/2)lamda
my r2 is the distance from B to Q which is Y meters
my r1 is the distance from A to Q which is Y + X meters
I'm trying to solve for lamda, but I don't know what m is. I know m has to do with "the longest wavelength" but I'm not sure how to calculate it. Or is it 0? I was guessing it would be 0 or 1. The book isn't clear. I hope you can help me!
You'll want to set r_2 = Y+X and r_1=X, in order to get r_2 - r_1 > 0 (otherwise you'll get a negative wavelenght).
Ok, where does the formula (r2 - r1) = (m + 1/2)lamda for destructive interference comes from? Let's try to understand it. It says that if the difference of the distances r_2 and r_1 is 1/2, 3/2, 5/2, etc. of the wavelenght, then we'll have destructive interference. Why? Because then the waves will arrive at point Q completely out of phase (completely = phase difference of pi), like illustrated here: http://scienceworld.wolfram.com/physics/DestructiveInterference.html
Ok, that explanation sucked. But the formula says that we have destructive interference at point Q whenever r_2-r_1 = (m+1/2)\lambda where m=0,1,2,3,.... Here, r_2 - r_1 = X, so the formula tells us that we have destructive interference whenever
X = (m+1/2)\lambda \Leftrightarrow \lambda = \frac{X}{m+1/2}
For which m between 0,1,2,3,... is lambda the biggest?
Thanks, that really clears things up, however I'm still confused a little. So by looking at the formula that equals lambda, I would assume that when m = 0, is when lambda is the greatest right? however the answer i am getting is still incorrect. Am i not understanding you correctly?
That's what I'd say too.
The answer is not 2X? What do they say it is?
okay.. my last comment.. ignore it, i wrote too soon! it was my fault i kept entering the wrong numbers in my calculator. thanks so much!
:biggrin:
