Two-Step backward differentiation
  • Thread starter Thread starter stvoffutt
    Differentiation
The discussion revolves around deriving a two-step backward differentiation formula with second order accuracy using Taylor expansion. The original poster presents an equation involving function values at different time steps and seeks clarification on the derivation process.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the validity of the original poster's derived formula and its accuracy order. There are suggestions to perform Taylor expansions around different points, specifically around \(y_{j+1}\) instead of \(y_j\). Some participants express confusion about the correct approach to expand the terms and relate them to the original equation.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants provide guidance on how to approach the Taylor expansions, while others express uncertainty about the correct formulation and the implications of the derived equation's accuracy.
There is a noted confusion regarding the indices and the terms involved in the expansion, as well as the implications of the method used for deriving the formula. The original poster is new to numerical analysis, which may contribute to the difficulties in understanding the concepts being discussed.
stvoffutt
By using Taylor expansion, derive the following two-step backward differentiation which has second
order accuracy:
[tex]\frac{3y_{j+1}-4y_j+y_{j-1}}{2h}=f(t_{j+1},y_{j+1})[/tex]
Taylor expansion
ODE
[tex]y^{\prime}=f(t,y) , y(0)=\alpha[/tex]
I find the expansion for [tex]y_{j+1}=y_j+hy^{\prime}_j+\frac{h^2}{2!}y^{\prime \prime}+\cdots[/tex]
and
[tex]y_{j-1}=y_j-hy^{\prime}_j+\frac{h^2}{2!}y^{\prime \prime}+\cdots[/tex]
This is where I get stuck. If I multiply [itex]y_{j+1}[/itex] by 3 and add [itex]y_{j-1}[/itex] I get the needed left hand side but the right hand side is [itex]f(t_{j},y_{j})=y^{\prime}_j[/itex]. How can I have an expansion that includes[itex]f(t_{j+1},y_{j+1})[/itex] that will yield the LHS of the derivation? Am I going about this all wrong? This problem seems relatively simple yet I think I am missing an important step.
Your equation doesn't have second order accuracy. It only has first order accuracy. Do your expansion around tj+1 and yj+1, going 1 step back and 2 steps back. You need to end up with an equation that has a zero coefficient for the second derivative.
It does have second order accuracy, Chester. This is an implicit integration technique as both the left and right hand sides involve yj+1.
stvoffutt, what this means is that you should be doing your expansions about yj+1 rather than yj.
I think you might have misunderstood what I said. The original equation does have second order accuracy, but stvoffutt's derived formula does not. My suggested method is the same as yours for deriving the original formula (featuring 2nd order accuracy).
Actually, stvoffutt wasn't able to derive a formula. That was his problem.
Actually, it was clear to me that that the formula he came up with was:
[tex]\frac{3y_{j+1}-4y_j+y_{j-1}}{2h}=f(t_{j},y_{j})[/tex]
This was the source of his concern. It didn't match the given equation. Also, he didn't realize that, as a consequence of the method that he used, this formula is not 2nd order accurate. The method that both you and I suggested will yield the desired formula, and the derivation will automatically lead to 2nd order accuracy (by requiring that the coefficient of the second derivative in the final equation is zero).
So should I expand like this?
[tex]y_{j+2}=y_{j+1}+2hy^{\prime}_{j+1}+\frac{4h^2}{2!}y^{\prime \prime}_{j+1}+\cdots[/tex]
and do the same thing for [itex]y_{j-2}[/itex]?
No. There is no yj+2 anywhere in the problem statement. You don't need it. You should expand yj and yj-1 in terms of yj+1.
I'm not sure how to expand y_j in terms of y_j+1. Can you point me in the right direction?
Sure you do. You did it right here:
Just relabel your indices.
[itex]y_j=y_{j+1}+hy^{\prime}_{j+1}+\frac{h^2}{2!}y^{\prime \prime}_{j+1}+O(h^3)[/itex]?
No. That's yj+2. You want yj.
[itex]y_j=y_{j-1}-hy^{\prime}_{j-1}+\frac{h^2}{2!}y^{\prime \prime}_{j-1}+O(h^3)[/itex]?
I'm sorry. I am having a hard time trying to keep all of this straight. This is my first course in numerical analysis.
No! Don't just guess. You want yj on the left, terms involving yj+1 and it's time derivatives on the right.
  • · Replies 18 ·
