Is the Prime Spiral an Intriguing Study or Just a Quirk?
Helical
I've was reading about it [http://mathworld.wolfram.com/PrimeSpiral.htm] and found it intriguing, has there been a great deal of study devoted to it or is it thought of as some kind of quark?
[P.S. I don't really know much about number theory, just curious]
I think it's fairly well-understood. The diagonals are related to prime-generating polynomials (which you can also read about on MathWorld).
but ALL the diagonals of Ulam spiral generate Polynomials that have prime values or only a few special diagonals of Ulam spiral only generate primes.
Be careful, no polynomial generates only primes indefinitely. I think you meant --only generate primes up to a large value of n --!
Uh.. sorry , then i meant what are the diagonals that generate primes up to a large value of 'n' or perhaps a bit harder , given a certain prime what is the Polynomial in Ulam Spiral that for a certain integer the Polynomial gives you the prime 'p' are there SERIOUS studies with calculations for Ulam spiral.
I'm working through that one, give me a bit.Parse tree:
Code:
(Uh.. sorry)
(then i meant
    (that generate primes up to a large value of 'n')
     (given a certain prime)
      (that for a certain integer)
 are there SERIOUS studies with calculations for Ulam spiral.)
Semantic re-formation:
Are there serious computational studies addressing:
1. What diagonals generate only primes up to large values of n?
2. Harder: given a prime p, what polynomials P have P(n) = p for some n?
Answer:
There are studies addressing #1. There is a close relationship between prime-generating polynomials and such serious topics as Heegner numbers (about which I know little). UPNT and MathWorld have lots of references.
#2 does not seem difficult. Do you have more conditions, or have I perhaps misunderstood you?
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
