Uncertainty of Time | Atomic Clocks & Pulsars
  • Thread starter Thread starter GingerBread27
    Time Uncertainty
Time standards are currently based on atomic clocks, with pulsars emerging as a potential alternative due to their stable rotation rates. A specific pulsar rotates every 1.424 806 448 872 75 2 ms, which allows for precise time measurement. Calculations show that this pulsar rotates approximately 1.27 billion times in 21 days and takes about 1424.8064 seconds for 1 million rotations. Uncertainty in these measurements can be determined using error propagation formulas, which simplify for single dimensions. The discussion highlights confusion regarding the calculation of uncertainty, suggesting a need for clearer methods.
GingerBread27
Time standards are now based on atomic clocks. A promising second standard is based on pulsars, which are rotating neutron stars (highly compact stars consisting only of neutrons). Some rotate at a rate that is highly stable, sending out a radio beacon that sweeps briefly across Earth once with each rotation, like a lighthouse beacon. Suppose a pulsar rotates once every 1.424 806 448 872 75 2 ms, where the trailing 2 indicates the uncertainty in the last decimal place (it does not mean 2 ms).
(a) How many times does the pulsar rotate in 21.0 days?
The answer is 1.27e9
(b) How much time does the pulsar take to rotate 1.0 x 10^6 times? (Give your answer to at least 4 decimal places.)
The answer is 1424.8064 seconds
(c) What is the associated uncertainty of this time?
For this problem I am unsure of how the uncertainty is calculated. I understand parts a and b but not C. Please help.
I think your answer to b) is off.
It's rotating once every 1.424 806 448 872 75 2 ms. so for it to rotate 1.000 time plus 0.0106 times, you're definitely not going to be in the 1400 second range.
That's about 20 minutes to go a little more than it was going in beyond less than a second. Recalculate that and you should get a better start for finding the uncertainty.
This answer is the right answer, but it should say: How much time does the pulsar take to rotate 1.0 X 10^6 times?
Use the error propogation formula:
s = \sqrt{ \left( \frac{\delta u}{\delta x} \right)^2_{y,z}s_x^2 + \left( \frac{\delta u}{\delta y} \right)^2_{x,z}s_y^2 + \left( \frac{\delta u}{\delta z} \right)^2_{x,y}s_z^2 }
This is the 3 dimensional [x,y,z] form of the equation. In this case you only have a single dimension, so, it simplifies to
s = \sqrt{ \left( nt \right)^2 s_t^2 }
where s is the total uncertainty, n is number of cycles, t is cycle time and s sub t is uncertainty per cycle.
I get some incredibly odd answer. I think this problem has a simple way that it should be solved and I just don't know what it is.
last minute hope lol can anyone help?
