Understanding Enthalpy and Entropy: Key Factors in Chemical Reactions
  • Thread starter Thread starter yifan
    Entropy
The enthalpy change for a specific compound varies with temperature and pressure due to the influence of bond energies and the proportions of products formed during a reaction. While enthalpy changes are constant for a given reaction, free energy changes fluctuate with temperature and pressure, affecting the spontaneity of reactions. At higher temperatures, the significance of the TdS term increases, impacting the overall enthalpy and free energy calculations. To determine if a reaction can occur naturally, one must consider free energy changes rather than relying solely on entropy values.
yifan
I've got two questions here.
Why is the enthalpy cahnge for a specific compound differs when temperature, pressure is different?
Can we use the entropy change to deduse whether an reaction can happen naturally?
Thank u
Chemistry news on Phys.org
The enthalpy change pertains to the level of the chemical equation and thus it is constant as long as the reaction takes place; since enthalpy changes pertains to bond energies. What you are referring to, I believe is, free energy changes. Free energy changes differ at different temperatures and pressures, which can be due to several reasons. For one, the rate of the unfavorable reaction will be increased relative to the favorable reaction at higher temperatures, thus the enthalpy of the reaction as a whole will be different at different temperatures since different proportions, relating to the chemical equation, of products will be formed (think enthalpy change per mole). Also at higher temperatures the value of TdS becomes significant. In order to calculate the spontaneity of a reaction one needs to know this free energy change, entropy value will not be sufficient.
Online help with college and high school chemistry
http://groups.msn.com/GeneralChemistryHomework
That is great, thank u again. :smile:
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
