Understanding Local Extrema with Two Variables and Partial Derivatives
  • Thread starter Thread starter Guero
    Extrema Local
To find and classify local extrema of the function f(x,y)=-x^2-y^2-10xy+4y-4x+2, the partial derivatives f_x and f_y are calculated as -2x-10y-4 and -2y-10x+4, respectively. Setting these derivatives to zero creates a system of equations that leads to stationary points. The equations can be combined to find specific solutions, ultimately revealing the stationary point (1/2, -1/2). However, further analysis shows that this point does not qualify as an extremum. Understanding the distinction between stationary points and extrema is crucial in multivariable calculus.
Guero
we're doing partial derivatives, and i thought i understood them until:
we are meant to find and classify all local extrema. i got:
f_x=-2x-10y-4 and f_y=-2y-10x+4
i've never had two variables at this stage, and i can't solve for any of the points. the text doesn't seem to say anything about this...
yay! I'm now a level 30 thumb twiddler
You solve \nabla f = \vec0 (gradient of f) which basically gives you a system of 2 equations here. The solutions are the 'stationary points' which may be extrema, but you have to check that (e.g. with a test)
So you solve:
\left\{ \begin{gathered}<br /> \frac{{\delta f}}<br /> {{\delta x}} = 0 \hfill \\<br /> \frac{{\delta f}}<br /> {{\delta y}} = 0 \hfill \\ <br /> \end{gathered} \right.
mm, i get: 10y=-2x-4 and 10x=-2y+4 for each of which there are infinite solutions for x and y. i thought that if i combined the equations (no reason) it might do it, but i still got y=x-1
Yes, you have to combine them in a system.
\left\{ \begin{gathered}<br /> 2x + 10y + 4 = 0 \hfill \\<br /> 10x + 2y - 4 = 0 \hfill \\ <br /> \end{gathered} \right.
Solving it should give \left( {\frac{1}<br /> {2}, - \frac{1}<br /> {2}} \right)
However, although it's a stationary point, it's not an extremum.
aha! thanks, i get it now
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
