Understanding Moles From Ideal Gas Law
The discussion revolves around the application of the ideal gas law and the calculation of moles from mass and molar mass. Participants explore the relationship between volume, mass, and pressure in the context of gases, specifically air, and clarify misconceptions regarding the properties of gases versus liquids.
  • One participant attempts to calculate moles using the formula moles = Mass(g) / Molar Mass, applying it to the ideal gas law with given values for volume, temperature, and a proposed molar mass.
  • Another participant questions the assumption that 120 L of air has a mass of 120,000 g, suggesting it seems excessively heavy.
  • Several participants clarify that 120 L refers to volume, not mass, and emphasize the need for pressure and temperature to accurately calculate moles of gas using the ideal gas law.
  • A participant proposes a calculation of the molar mass of air based on its composition of oxygen and nitrogen, arriving at a value of approximately 28.59 g/mol.
  • Another participant points out that the calculated mass of gas in 120 L leads to an unrealistic pressure of 870 atm, indicating that this is outside the ideal gas region for air.
  • There is a reiteration that the ideal gas law applies to gases, and the molar mass of air is approximately 29 g/mol, not 16 g/mol as initially suggested.
Participants express disagreement regarding the mass of air in a given volume and the implications of that mass on pressure calculations. There is no consensus on the validity of the initial calculations presented, and multiple competing views remain regarding the application of the ideal gas law.
Participants highlight the importance of knowing pressure and temperature alongside volume to accurately apply the ideal gas law. The discussion also reflects confusion regarding the properties of gases versus liquids and the correct molar mass of air.
Kayne
Hi All,
I would like to understand a little more about the following equation
[tex]moles = \frac{Mass(g)}{Molar Mass}[/tex]
I know that this is to calculate the Moles for use in the ideal gas law equation
[tex]PV=n \times R \times T[/tex]
Lets say I had to find two variable in the ideal gas law one being Pressure the other moles. If I know that the volume of a tank is 120L of Air and the molar mass is 16 is this enough to work out this equation??
[tex]moles = \frac{120000}{16}= 7500[/tex]
Now can this be substituted back into the ideal gas equation with the following
V = 120L
n = 7500
R = 0.0821 L.Atm/mol.K
T = 303 K
[tex]P=\frac{7500 \times 8.314 \times 303}{120} = 1554 kPa[/tex]
Is this correct?
Science news on Phys.org
How do you figure that 120 L of air has a mass of 120000 g (120 kg)? That seems a bit heavy to me. :rolleyes:
No, isn't.
When you say 120L you're talking about volume, not about mass.
Ok yes you are correct that is volume. Does this mean that the equation is correct??
Put another way if it was 20 Liters of water
20Litre = 20 Kg = 20 000grams then
[tex]Moles = \frac{20 000}{16 }= 1250[/tex]
I guess I am trying to get my head around what the weight of air is when compressed into a 120L cylinder and if this is proportional to the volume of the cylinder.
The ideal gas law applies to gas, not to liquid. Liquid water may weigh 1000 kg per liter, but gaseous water weighs much less. If you know the volume of the tank, you also need to know the pressure and the temperature in order to calculate the number of moles of air in the tank (using the ideal gas law). Once you know the number of moles, you can calculate the mass of air in the tank by multiplying by the molar mass. Incidentally, the molar mass of air is 29 (a weighted average of the molecular weight of oxygen and nitrogen), not 16.
I have been doing some more digging and would like to test my theory
The molar mass of air is a make up of 21% Oxygen & 78% Nitrogen
[tex]O_2 = 2\times 16 = 32 g/mol[/tex]
[tex]N_2 = 2\times 14 = 28 g/mol[/tex]
Therefore
[tex]O_2 = 32 g/mol \times 0.21 = 6.7 g/mol[/tex]
[tex]N_2 = 28 g/mol \times 0.78 = 21.84 g/mol[/tex]
[tex]Air = 21.84 + 6.8 g/mol = 28.59 g/mol[/tex]
If I have a volume in a tank of 120L this works out to be 120000grams and I have the Air Molar mass can I now calculate the moles?
[tex]Moles =\frac{120000 grams}{28.59 grams/mole} = 4197 moles[/tex]
If this is correct then I should be able to substitute any mass in there to work out the moles.
I then should be able to work out the ideal gas law if I want to find the pressure
lets say V = 120L, R= 0.0821atm.L/K.Mol T =303K n =4197 mol
[tex]P = \frac{n \times R \times T}{V}[/tex]
[tex]P = \frac{4197 \times 0.0821 \times 303}{120}[/tex]
= 870atm or 88149 kPA or 12785 PSI
Any guidance is appreciated
Several people (including myself) have already said that the mass of gas in 120 L is not generally 120 kg. Why do you keep assuming that it is? In order for air to have that density, you have shown in your calculations that its pressure would have to be 870 atm. So what? In addition, this is outside the ideal gas region for air, so the estimate of 870 atm. is inaccurate.
Chestermiller,
I did not see this reply when I posted my last post so this was not intentional.
  • · Replies 19 ·
  • · Replies 23 ·
  • · Replies 109 ·
9K
  • · Replies 22 ·
