Understanding Residual Stresses: Books & References
  • Thread starter Thread starter dilberg
The discussion focuses on understanding and modeling residual stresses in finite element analysis (FEA), particularly in relation to fatigue cracks and welding processes. Participants recommend exploring literature and resources, including a specific NASA paper on magnetoacoustic residual stress measurements. There is a debate on whether to apply residual stresses as a predefined field or simulate them through processes like welding, with emphasis on the transformation of thermal strain into mechanical strain. Users express challenges in implementing these concepts in ANSYS software, particularly in modeling residual stress patterns accurately. The conversation highlights the complexity of modeling residual stresses and the need for clear methodologies to achieve accurate results.
dilberg
I'm having some trouble understanding residual stresses. I need to model a residual stress pattern into a finite element model. Can someone recommend books or references that has computations with residual stresses?
See this paper
http://techreports.larc.nasa.gov/ltrs/PDF/conf-rpqnde-92-p1863.pdf
FINITE ELEMENT MODELING OF THE BULK MAGNITIZATION OF RAILROAD
WHEELS TO IMPROVE TEST CONDITIONS FOR MAGNETOACOUSTIC
RESIDUAL STRESS MEASUREMENTS
J. P. Fulton and B. Wincheski
Analytical Services and Materials, Inc.
107 Research Drive
Hampton, VA 23666
M. Namkung
NASA, Langley Research Center
Google "residual stress","finite element analysis" and see what pops up.
I got stuck with your "into" ... are you interested in applying residual stresses as a predefined field in FEA or carry out a residual stress simulation (for example of welding or whatever 'process' results in the existence of residual stresses) of something particular?
As PerennialII mentioned, it would be useful to know the area of particular interest. For example, welds do have residual stress, particular fusion welds in the area of final solidification. Hot tearing can be a problem.
One challenge in FEM of solids or systems involving phase change from solid to liquid is the transformation of thermal strain into mechanical strain. Thermal strains 'do not' produce stress, mechanical strains do - and this is a key factor in modelling dynamic thermal systems with rapid temperature changes which cause a rapid redistribution of mechanical load - as well as changes in the yield and ultimate strengths - i.e. shift in the plastic or yield curve.
I am interested in effect of residual stresses on fatigue cracks. I have a parametric model of a fracture specimen, and I am trying to model residual stress pattern (due to prior yielding, probably due to fluctuating loads) as a predefined field as PerrenaII mentioned. From literature I gather that this could be done by modeling the residual stress pattern as a thermal strain field and I have been trying to this for a while now without much success. I am using ANSYS. I would be grateful for any help anyone can give me about this.
Sounds doable, however can be done with various degrees of complexity like Astronuc's answer already implies (seems to apply quite generally to residual stress problems). I'm thinking is the thermal strain approach you're after in this case just a substitute problem to get the analysis (and Ansys especially) to accept (to take in) the initial stress field (or/and are you using it to transfer a solution from a model without a crack to a one with a crack)? Such steps are quite often done in these types of problems, alternatively would have to consult Ansys manuals, whether the software accepts an element by element (or node by node, integration point by integration point) input of an initial residual stress state to an analysis (if you'd have a literature/previous solution available you could use it then via such a procedure). I'd say it does, but am not 100% sure.
Next, you could naturally try to do the analysis which would actually lead to the existence of the residual stress field - for example an appropriate nonlinear elastic-plastic analysis of your configuration under fluctuating loads and see what results, and transfer the results of your 1st analysis as input to your 2nd, fatigue crack analysis. Are we getting anywhere towards the right track?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
