Understanding Stokes Theorem: Solving Boundary Curve Dilemmas in Vector Calculus
7 replies · 3K views
swraman
This is a question about stokes theorem in general, not about a specific problem.
Directly from lecture:
"If S has no boundary (eg. if S is the boundary of a solid region) then [tex]\int\int_{S}Curl(\stackrel{\rightarrow}{F})\bullet ds = 0[/tex] "
because apparently "no boundary C exists"
However in the next example he gives S is a hemisphere or radius 1 above the XY plane; and he uses the projection of the hemesphere on the XY plane as the bondry curve C and it works out fine.
Isnt the hemisphere a boundary of a solid region? So shoudn't the integral be zero? Why can you use the boundary of the projection of S on the XY plane as the curve C?
This is hard to explain in words, if someone is so kind as to lok into this, you can see exactly what I am seeing here:
http://webcast.berkeley.edu/course_details_new.php?seriesid=2008-D-54472&semesterid=2008-D
Lecture 42, 4:00-5:00 is where he says the integral is zero, then at 9:40 he does the example with the hemesphere and it is not zero.
[tex]\int\int_{S}Curl(\stackrel{\rightarrow}{F})\bullet ds = \int_{C}\stackrel{\rightarrow}{F}\bullet d\vec{r}[/tex]
Thanks anyone willing to look/help :)
the boundary of a boundary is zero
Hi swraman! :smile:
(I haven't watched the webcast lecture you linked to but:)
The boundary of a boundary is zero (empty).​
The boundary of a solid hemisphere is a hemipherical shell plus the "base".
In your example, the surface S is only the hemipherical shell.
So S is not the boundary of a solid object, and S's boundary is therefore not zero. :wink:
tiny-tim said:
Hi swraman! :smile:
Thanks for hte reply.
Im still a little confused; so is the shell of a full sphere considered to be a "boundary"? But a hemisphere's shell isnt?
The surface surrounding any solid object is a boundary …
a spherical shell does surround a sphere, so it is the boundary of the sphere …
but a hemi-spherical shell does not surround a hemi-sphere: the hemi-sphere is surrounded by the hemi-spherical shell and the base :smile:
so...if the surface can be expressed as a single function it is a boundary?
Nooo … if the surface divides space into two, ie if it surrounds a solid volume, then it is a boundary.
This is even if it's in two parts (i assume that's what you would call "two functions"), like a hemispherical shell and a disc. :smile:
doesnt the hemisphere shell surround a solid region?
i'm not sure we're talking about the same thing …
a solid hemisphere is surrounded by a curved piece and a flat piece …
i'm calling the curved piece the "hemisphere shell", and the flat piece the "base" or the "disc" …
so the hemisphere shell on its own is not the boundary of a solid region, and so its boundary C is not the boundary of a boundary. :smile:
