Uniform acceleration kinematics lab
The discussion revolves around a physics lab involving a cart on a ramp and the analysis of distance-time (d-t), velocity-time (v-t), and distance-time squared (d-t^2) graphs. Participants clarify that the slopes of these graphs represent acceleration, but discrepancies arise when comparing the slopes calculated from different graphs, leading to confusion about the results. It is confirmed that the slope of the d-t^2 graph should yield half the acceleration of the cart, while the v-t graph directly reflects acceleration. The conversation emphasizes the importance of correctly plotting the graphs and understanding the relationships defined by kinematic equations. Ultimately, the participants reach a consensus on the interpretation of the graphs and their implications for understanding motion.
Trevormbarker
This is more of a general question but it is part of my physics course so i decided to post here, I am sure many of you have done this lab but what it is is a cart with tickertape attached to it going down a ramp, once we plot a d-t graph there are lots of application questions. One of them says plot a d-t^2 graph and a v-t graph, it says to calculate the slope of each graph and compare them.
None really just slope, (y2-y1)/(x2-x1)
By looking at the units i thought that the slope of each graph should both represent acceleration as cm/s^2 and (cm/s)/s are the same thing, since they came from the same data set they should have the same slope but I get two different slopes, they are exactly off by a factor or 2. Am I making an arithmatic error or is it supposed to be like this, ( I get a slope of 61 for the d-t^2 graph and 120 for the v-t
What is the equation that relates velocity with acceleration and time? What is the equation that relates distance with acceleration and time?
v2^2=v1^2 + 2aD?
D= v1T + 1/2aT^2?
im sorry but I am not sure what exactly you are getting at? why are my accelerations different if the units worked out correctly and they were both taken from the same data set
Your 2nd equation relates distance with acceleration and time,
D = 1/2at^2
you didn't express the equation which relates velocity with acceleration and time,
v = at
Now when you plot v vs t, the slope of the line is a , correct?
Now plot D vs. t^2. The slope of the line is ?
D vs t^2 should also be acceleration no! m=rise/run = D/t^2= cm/s^2
Or are you implying I use your D=1/2at^2 and t^2 for it and do (1/2at^2)/(t^2) which leaves me with 1/2 a. Which makes sense slightly but what is this the acceleration for? And howcome it doesn't work when i just use the units on the axis, only when i use an equivelant relationship to D
When you plot D vs. t^2, you should get more or less a straight line sloping up and to the right. Since distance = 1/2 at^2 (d = mt^2, where m is the slope)then the slope of the line is ?. Be sure to plot distance on the y axis, and time squared (not time) on the x axis.
1/2a. Thanks for all the help I just don't understand what this acceleration represents. Is it just the graph is set up like the kinematic equation so "solving for the slope" is really just isolating the 1/2a, being 1/2 of the acceleration of the cart. Is doing D over t^2 times 2 just the graphical equivelent of the kinematic equation. I think that's all been cleared up thanks alot. What is the the actual graph, ie what does it really mean, when i read it what information can i extract without differntiating or integrating it.
