What is the Simplified Equation for a Uniform Electric Field?
The discussion focuses on finding a simplified equation for a uniform electric field. Participants express difficulty in achieving the correct simplification and understanding the mathematical equivalency of their answers. A suggestion is made to factor out 1/4 from the square root to aid in simplification. Additionally, there is a concern about properly tracking the factors of a/2 in the calculations. The conversation emphasizes the need for clarity in mathematical steps to reach the correct solution.
Goatscholar18
[/IMG]
See Below
Maybe my answer is right but not simplified enough. But if it is I am having trouble seeing the mathematical equivalency. Please help.
Thanks in advance!
Most of that is hard to read, but if you just ask about the answer: Factor out 1/4 in the square root and then get it out of the square root.
Also, I don't think you kept track of the factors of a/2 circled below
