Calculating Speed of Rotating Disks and Hoops Using Uniform Solid Disk Equations
The discussion focuses on calculating the speed of a uniform solid disk and a hoop as they rotate about a pivot. For part (a), the correct speed of the center of mass for the disk is found to be √(4gR/3). Part (b) presents challenges, with participants unsure how to calculate the speed of the lowest point on the disk. In part (c), the method for the hoop should mirror that of the disk, but the moment of inertia for the hoop must be applied correctly to avoid incorrect results. Clarification on showing work is suggested to facilitate better assistance.
aborder
A uniform solid disk of radius R and mass M is free to rotate on a frictionless pivot through a point on its rim (see figure below). The disk is released from rest in the position shown by the copper-colored circle.
(a) What is the speed of its center of mass when the disk reaches the position indicated by the dashed circle? (Use any variable or symbol stated above along with the following as necessary: g.)
(b) What is the speed of the lowest point on the disk in the dashed position? (Use any variable or symbol stated above along with the following as necessary: g.)
(c) Repeat part (a) using a uniform hoop of mass M. (Use any variable or symbol stated above along with the following as necessary: g.)
KEf + Uf = KEi + Ui
1/2Iω2
Impulse for disk = 1/3MR2
Vcm = Rω
KE = 1/2MV2
U = mgR
Part A I got the right answer of \sqrt{}4gR/3
Part B is giving me some issues and I suppose I am not sure where to go with it.
Part C I figured I could use the same method as part A, but for some reason, I get \sqrt{}2gR and that is no good.
All you have to do for the hoop is to use the same method as you did for the disc but with the moment of inertia for the hoop. If you show your work one can help you better.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
