Unit conversion inside a derived gausses law eq
The discussion revolves around converting the unit \(\alpha = \frac{15 \text{ cm} \cdot \text{m}^3}{\mu \text{C}}\) into meters per coulomb. The user struggles with unit conversions, specifically how to handle the centimeter to meter conversion and the microcoulomb to coulomb conversion. They attempt various calculations but are unsure about their results, particularly the expression \(1.5 \times 10^{-7} \text{ m}^4/\text{C}\). The confusion stems from the complexity of the units involved, and the user expresses frustration over the problem's difficulty. Ultimately, the user seeks clarity on the correct conversion method.
bobasp1
Essentially I'm working out a problem and I am given \alpha = \frac{15cm\bullet m^{3}}{\mu C}
and I need to get it in just terms of meters/coulombs
I'm having a real tough time with weird unit conversions like this.
1m = 100cm 1 micro coulomb = 1 X 10^-6 coulombs
1m/100cm * 10^-6 micro c/1c * the above eq. 1.5 x 10^-7 m^4/C pretty sure that isn't correct.Thanks
15 cm*m^3/micro C* 1Micro C/1X10^6 C *1 m/ 100 cm
Thanks
the 10^-6 of micro coulomb will become 10^6 when it goes up
and whatsthat m^3 with 15cm
bahh >__< i had it right, I guess my problem isn't correct then Thanks everyone
1.5e-7 m^4/C
no clue why, its from quest homework service and the problem it self is pretty chill, but that one variable is screwing with me.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
