Calculating EMF Induced by a Moving Wire in a Magnetic Field
  • Thread starter Thread starter Sir_Pogo
    Coil Emf
Sir_Pogo
Can i get some help with this homework problem??
A physicist wraps a long copper wire around a toilet paper roll and places the roll in a uniform magnetic field. The axis of the roll is aligned with the field. The radius of the roll is r = 6 cm and the strength of the field is B = 0.1 T. If the physicist pulls the wire at v = 78 cm/s, what is the magnitude of the EMF induced in the wire?
Thanks in advance.
Look at the equation for induced emf related to the flux through a coil of N turns. What is changing when the wire is being pulled? The wire is unwinding from the roll.
im using dBda/dt and da/ta= .5*r*ds/dt where ds/ts is the velocity
im taking that time the magnetic field.
also i am watchin my units.
so B*.5*r*v=emf? what's wrong its not right tho?
I don't understand your first equation. Is d the diameter in one place and derivative in another? I think you need to be a bit creative with this one. Usually we take N to be a constant and write
ε = -N[dΦ/dt] = -N[d(BA)/dt]
But in this problem, B and A are constant and effectively N is changing, so
ε = -[d(NAB)/dt)] = = -BA[dN/dt]
How is N related to v?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
