Electrical Unused light switch in the living room?
  • Thread starter Thread starter arabianights
arabianights
hi guys
I have a switch mounted on the wall in my living room that doesn't control anything, it's on the opposite side of stairwell to the basement and below the HVAC vent. the light switch to stairwell is in the same space of stairs. and the living room ceiling light is controlled on the far side near the kitchen.
the townhouse was built by Pulte in the mid 80s if that helps.
How do you know it is unused? When you pull the plastic faceplate off, do you see any wires going to the switch? (Don't pull the switch itself out of the wall.)
Oftentimes, such a switch will control an outlet, so that a floor lamp can be controlled via the wall switch. Are there any outlets nearby? Can you use a socket tester or even just a lamp to test to see whether the switch is controlling it?
Likes Lnewqban, BillTre and phinds
It's not uncommon for a receptacle to be split. For instance the bottom may be live all the time but the top is controlled by the switch.
Likes BillTre, russ_watters and berkeman
First thing I would do would be to check it with a wire detector (few bucks for a basic model).
Three rabbits will be wintering in a 2m x 2m x 2m wooden hut. Outside temperature does not go below -30c (-22f) Planning to put a 50cm by 50cm 1mm thick stainless steel sheet on the floor of the hut (inside off course) My plan is to heat the sheet with a 50w PTC heater element https://fi.rsdelivers.com/product/dbk-enclosures/fg135600/dbk-enclosures-heating-element-75mm-50-w-100-240-v/dc/2995922?backToResults=1 Is this heater (50W) enough to keep the pad warm enough to sustain liquid...
Hey all. I'm looking to buy a zero-turn mower and I need to build/purchase a ramp to get it into my shed for storage. Exact model is this one. I need to figure out how long of a ramp I need to make sure the mower doesn't bottom out when driving up and down the ramp. Mower stats: Wheelbase: approximately 76 inches. Height: 4.5 inches (based off the highest setting on the deck height adjustment) Shed entrance is 12 inches off the ground. The manufacturer says that the mower can handle...
