Electrical Unused light switch in the living room?
  • Thread starter Thread starter arabianights
An unused light switch in a living room may not be truly inactive, as it could control an outlet instead of a light fixture. To determine its function, check for wires behind the faceplate without removing the switch. Nearby outlets should be tested with a socket tester or lamp to see if they are controlled by the switch. It's common for outlets to have split functionality, where one part is always live and the other is switch-controlled. Investigating with a wire detector can provide further clarity on the switch's purpose.
arabianights
hi guys
I have a switch mounted on the wall in my living room that doesn't control anything, it's on the opposite side of stairwell to the basement and below the HVAC vent. the light switch to stairwell is in the same space of stairs. and the living room ceiling light is controlled on the far side near the kitchen.
the townhouse was built by Pulte in the mid 80s if that helps.
How do you know it is unused? When you pull the plastic faceplate off, do you see any wires going to the switch? (Don't pull the switch itself out of the wall.)
Oftentimes, such a switch will control an outlet, so that a floor lamp can be controlled via the wall switch. Are there any outlets nearby? Can you use a socket tester or even just a lamp to test to see whether the switch is controlling it?
Likes DaveE, Lnewqban, BillTre and 1 other person
It's not uncommon for a receptacle to be split. For instance the bottom may be live all the time but the top is controlled by the switch.
Likes OmCheeto, DaveE, BillTre and 2 others
First thing I would do would be to check it with a wire detector (few bucks for a basic model).
My last house had a switch that controlled a louver to the upstairs HVAC so you could shut it in the summer when the upstairs got too hot.
Since it's a town house, you might try asking your neighbors if they have one too and what it does.
Likes OmCheeto and berkeman
Three rabbits will be wintering in a 2m x 2m x 2m wooden hut. Outside temperature does not go below -30c (-22f) Planning to put a 50cm by 50cm 1mm thick stainless steel sheet on the floor of the hut (inside off course) My plan is to heat the sheet with a 50w PTC heater element https://fi.rsdelivers.com/product/dbk-enclosures/fg135600/dbk-enclosures-heating-element-75mm-50-w-100-240-v/dc/2995922?backToResults=1 Is this heater (50W) enough to keep the pad warm enough to sustain liquid...
