Ur in a room with a magnet and an iron bar how do u know which one is the magnet
In summary, you need to place the magnets so that they are in the middle of the poles, so that they have an attraction to each other.
cragar
2,552
ur in a room with 2 iron bars one is a magnet and the other is not , they are the same shape
and size , how do u tell which one is the magnet and all u have is the 2 bars to test this nothing else in the room.
Ooo, Ooo, I know, I know.
Is this for homework/coursework, or a Brain Teaser? Do you have an answer you can PM me, so I can allow the thread to continue?
this was asked to my physics class and i was just wondering if someone
could tell me , cause my teacher didn't tell us yet.
Well, we're not going to do your classwork for you. I'll move this to the Homework Help forums, and offer you one clue... You need to figure out this homework/coursework yourself (see the "Rules" link at the top of the page).
Hint -- what things can you do with a magnetized iron bar that you cannot do with non-magnetized iron bar?
its not for homework
Your teacher asked you the question, and so far nobody in the class has figured it out. That makes it homework/coursework, as defined by the PF Rules.
My hint didn't help at all?
not really how would u tell which bar pulled which
I didn't say anything about pulling in my hint. Do you have a study group for that class, or some classmates that you can discuss it with? Give my hint to your study group/friends, to see if it sparks a good discussion where you can come up with the answer I have in mind.
I know the answer, but I assume from this thread that I am not to reveal it.
Correct, thank you. If you can provide a not-too-obvious hint, though, that is okay. The OP (and his study partners or whatever) really need to do the work on this assignment. It looks like the professor is trying to make them think some :biggrin:
k so where would i move this so some one can answer it.
We don't do your work for you. This is the PF, and we all (generally) abide by the Rules here, beause they're important.
How would you benefit in the long term if we gave you the answer? In the short term, you would gain a bit in your grade, and in your standing in the class (assuming you lied about how you came up with the answer). In the long term, you would be hurt academically and professionally, because you wouldn't be developing the creative technical thinking skills that your prof is trying to engender with his/her question.
Honestly, the hint that I gave you was a bit too obvious, and I should probably give myself an infraction for giving away a homework question answer. Bounce the hint off of your friends in the class, and turn it into a brainstorming session.
If you rely on others to give you the answer to hard questions in your school work, then I can guarantee that you will fail my interview questions when you try to get a real job with your "hard-earned degree".
C'mon, I practically gave the dang answer away!
would u place the magnets in a T fashion
Not what I had in mind, but tell us why you think that might help...
if u place them in T fashion and if there is an attraction the bottom one is the magnet
and if there is no attraction the top one is the magnet because u are in between the poles, what did u have in mind.
Hey, that's not bad! I didn't think of that angle -- I'll remember that one.
No, that's not what I had in mind. Bet you get extra credit if you and your study group figure out what I meant by my hint. Even more credit if you give attribution to the PF for the hint (shows academic integrity on your part).
BTW, the "T" solution is more elegant than mine. But when you're faced with a life-or-death McGiver situation, you do what you have to do!
k i still have no clue how u would do it does it have something to do with electricity.
Nope. Per your problem statement, you are in the room with the two bars in your non-conducting pajamas.
Re-post my hint here again, and brainstorm a bit... You'll figure it out. Talk out loud...
make a compass out of it
YES! (now be honest, did you think that up, or did your study group do it in group brainstorming? Either way is okay, just get used to being honest about who-all contributed).
But you're not done. There are two decision trees, depending on whether you tried to magnetize with the magnet first or the iron bar first. For full credit (both here and at your school), post how you use this trick not knowing if the bar you swipe over the other is the magnet or not...
(good job!)
so in a way it did haft to do with electricity cause isn't magnetism the movement of eletric charges.
Not from my perspective.
Quiz Question #2 -- When is magnetism not generated by elecricity?
maybe like when the sun and all its isotopes roatate , or maybe the nuetron magnetic moment. what is the particle of the electro magnetic field.
1. How can I tell the difference between a magnet and an iron bar in a room?
There are a few ways to determine whether an object is a magnet or an iron bar. One method is to use a compass. If the object is a magnet, it will cause the compass needle to move and point towards it. Another method is to try to pick up small metal objects with the object in question. A magnet will attract these objects, while an iron bar will not.
2. Can I use a magnet to test if an object is made of iron?
Yes, a magnet can be used to test if an object is made of iron. If the object is attracted to the magnet, it likely contains iron. However, this method is not foolproof as some non-iron metals can also be attracted to magnets.
3. Is there a way to tell the strength of a magnet without any special equipment?
Yes, there is a simple test you can do to determine the strength of a magnet. Take a paperclip and try to pick it up with the magnet. If the magnet can easily lift the paperclip, it is a strong magnet. If the paperclip falls off or is not easily lifted, the magnet is weaker.
4. How can I tell if an object is a permanent magnet or an electromagnet?
An easy way to determine if an object is a permanent magnet or an electromagnet is to try to pick up small metal objects with it. If the magnet can pick up the objects without any external power source, it is a permanent magnet. If it only has magnetic properties when connected to a power source, it is an electromagnet.
5. Can the polarity of a magnet be determined without any additional tools?
Yes, you can determine the polarity of a magnet by using another magnet. Hold the two magnets close together without touching. If they repel each other, they have the same polarity. If they attract each other, they have opposite polarities.
  • Electromagnetism
