Solve Physics Problem: Urgent Cessna-182 Plane Mass 1290kg Glide Angle
  • Thread starter Thread starter sid88
    Physics Urgent
The discussion centers on a physics problem involving a Cessna-182 airplane with a mass of 1290 kg experiencing engine failure and gliding at a constant speed of 139 km/h. Key calculations include determining the glide angle, which is found to be 5.76 degrees, and the lift force, calculated at 12654.9 N. Participants discuss the method for calculating the rate of gravitational potential energy loss, emphasizing the use of the formula U = mgy and the need to find the rate of change of altitude. There is also a scenario where the pilot restarts the engine, requiring the calculation of the flight angle when climbing at a steady rate of 5.61 m/s. The thread highlights the application of physics principles to solve real-world aviation problems.
sid88
A fully loaded Cessna-182 airplane of mass 1290kg has an engine failure when flying with an airspeed of 139 km/h at an altitude of 2710 m on a calm day. it then glides at a constant glide angle(which is the direction of flight below the horizontal) towards a safe landing at this constant speed of 139km/h experiencing a drag force of 1270 N that opposes the directin in which the plane is moving.
i) Find the magnitude of:
a) The glide angle
5.75 degrees
b) The lift force.
12654.9 N
c) The rate at which the loaded plane is losing gravitational potential energy[/B]
ii) Suppose the pilot instead had managed to get the airplane engine started such that he was able to apply full throttle and the airplane climbed along a straight line angled above the horizontal so that it gained altitude at a steady rate of 5.61 m/s. Assuming he was again flying with an airspeed of 139km/h determine:
i) the flight angle above the horizontal the plane is flying.
I have already found the glide angle and lift force using F = mg cos(theta)
The glide angle is 5.76 degrees
The lift force is 12654.9 N
Hi sid88,
The gravitational potential energy for this problem is U=mgy. The rate of change of U is the rate of change of mgy. Since m and g are constants, can you find the rate of change of y?
Once you find that, a quick multiplication will give you the rate of change of mgy.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
