Using a Power Series to approximate a definite integral
The discussion centers on using a power series to approximate the definite integral of the function defined by the series \( \frac{1}{1-x} + \frac{x}{1-x} \). The integral is evaluated from 0 to \( \frac{1}{10} \), resulting in \( \frac{1}{10} + \sum^{\infty}_{n=1} \frac{(1/5)^{n+1}}{n+1} \). Participants clarify the error estimation method, specifically using the formula \( \frac{M}{(n+2)!} (b-a)^{n+2} \) to ensure the error remains below \( 10^{-5} \). The conclusion reached is that \( N=4 \) terms should be used for an acceptable approximation.
  • Understanding of power series and their convergence
  • Familiarity with definite integrals and integration techniques
  • Knowledge of error estimation in numerical methods
  • Ability to differentiate functions and evaluate derivatives
  • Study Taylor and Maclaurin series for better approximation techniques
  • Learn about error bounds in numerical integration methods
  • Explore the concept of convergence and divergence in series
  • Investigate the use of factorials in error estimation formulas
Mathematics students, educators, and professionals involved in numerical analysis or calculus, particularly those focusing on series approximations and error analysis.
Bazzinga
[PLAIN]http://img600.imageshack.us/img600/1210/11096142.png
Hey I was wondering if you guys could help me out with this question...
I think I have the right power series:
= \frac{1}{1-x} + \frac{x}{1-x}
= (1+x+x^{2}+x^{3}+...)(x+x^{2}+x^{3}+x^{4}+...)
= 1+2x+2x^{2}+2x^{3}+2x^{4}+...
= 1 + \sum^{infinity}_{n=1} 2x^{n}
Then I integrate to get:
\int^{1/10}_{0} 1 + \sum^{infinity}_{n=1} 2x^{n} dx
=x + \sum^{infinity}_{n=1} \frac{2x^{n+1}}{n+1}|^{1/10}_{0}
= \frac{1}{10} + \sum^{infinity}_{n=1} \frac{(1/5)^{n+1}}{n+1}
So I have the integral, I'm just not sure how to find an answer such that the error is less than 10-5 (I've never been any good with errors...)
We did learn in class today something where the error is less than
Am I supposed to rearrange this formula? And what's M?
If you keep n+1 terms in your sum and neglect the rest, this formula gives you the (maximal) error you can have. M is the maximum of the (n+1)-st derivative of your function over the interval [a,b]=[0,1/10], which is in your case given by the next term in the power series, the first one you neglected, times (n+1)!, since you use a power series and not (directly) the derivative.
Beware: you may have to change n+1 for n+2 above, I'm not quite sure there, usually one truncates a series at the termn and then in the formulae there are n+1's insteadof the n+2 you gave us ...
One other note: When evaluating the limits inside the Sigma, exponentiation takes precedence over multiplication by coefficients. For 2 * x^(n+1) evaluated at x = 1/10, the correct evaluation is expressed as 2*(1/10)^(n+1), so that (1/10) is raised to the power (n+1) BEFORE multiplying by 2.
I must have copied down the formula wrong, woops!
Im still not understanding.. I can find the error when finding an approximation for the series, but I don't understand how to find an approximation of the series when I have an error...
Instead of summing all terms in your result up to n=infinity, you just sum until a finite n=N. This is your approximation. Of course it isn't correct, but there comes the error formula: it tells you how big your mistake can be at most.
Therefore, you have to find a N such that the error, evaluated for that N, is smaller than 10^(-5), and use this N. (You should get N=4).
I ended up using trial and error and I ended up with N=4. I'm not sure if there's a better way to find M, but I made a list of derivatives and found it that way and that worked! Thanks!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
