Using double integration to find area of a cylinder
The discussion focuses on calculating the area of a cylinder defined by the equation x²+y²=1, specifically the portion above the xy-plane and below the plane z=3y. The user attempted to parametrize the function using r(t,z)=icos(t)+jsin(t)+kz and computed the necessary partial derivatives. An error in the limits of integration was identified, where the correct limits for t should be from 0 to π instead of 0 to 2π. After correcting this, the user successfully found the correct area.
  • Understanding of double integration techniques
  • Familiarity with cylindrical coordinates
  • Knowledge of vector calculus, specifically cross products
  • Proficiency in parametric equations
  • Study the application of double integrals in cylindrical coordinates
  • Learn about parametrization of surfaces in three-dimensional space
  • Explore the concept of limits in integration and their impact on results
  • Investigate vector calculus operations, particularly cross products and their geometric interpretations
Students in calculus or engineering courses, educators teaching multivariable calculus, and anyone interested in applications of double integration in geometric contexts.
liishii
Find the area of that portion of a cylinder x^2+y^2=1 lying above the xy-plane and below the plane z=3y.
dr=sqrt(1+fx2+fy2[/SUB])dxdy
or
dr=|ru x rv| dudv
I attempted to parametrize the function in terms of theta (t) and z. I got r(t,z)=icost+jsint+kz. Then, I found the partials with respect to t and z and got: rt=-sinti+costj and rz=z, where t=0 to 2pi and z=0 to 3y=3sint.
I took the cross product of the two partials to get icost+jsint+0k. I used the cross product to find |rt x rz|=1. Then, plugging this into the second equation above, I got the answer to be 0, which is incorrect. What am I doing wrong?? Thanks for your help!
Your limits for t are wrong. Remember, you only want the part above the xy-plane.
oh that makes sense! so the t limits had to be from 0 to pi, not 2pi.
I got the right answer! Thanks so much vela!
