Engineering Using knrnaugh maps to design a circuit
  • Thread starter Thread starter MasterWu77
    Circuit Design
The discussion focuses on designing a circuit to convert Excess-3 code to BCD using Karnaugh maps. Participants emphasize the importance of creating a truth table for the Excess-3 inputs, detailing the corresponding BCD outputs. They suggest using the sum of products form for each output derived from the K-map to implement the circuit. Additionally, there is advice for beginners to practice turning K-maps into circuits and to seek further resources for clarification. Overall, the conversation highlights the learning process involved in mastering circuit design with Karnaugh maps.
MasterWu77
Design a circuit to covert a number represented in Excess-3 code to BCD. You must use karnaugh maps in this problem. provide a circuit diagram as well.
Using the karnaugh man
I understand the basics of a Karnaugh map but I'm not sure of how to turn a karnaugh map into a circuit. What exactly is an excess 3 code and how would i use that to make my circuit?
http://en.wikipedia.org/wiki/Excess-3
from this info you can develop a truth table for your excess-3 inputs, with 5 output columns also in the truth table, one for each digit of the BCD number.
Something like: A-D = inputs, Fs = outputs
A B C D F4 F3 F2 F1 F0
0 0 0 0 1 1 1 0 1
0 0 0 1 1 1 1 1 0
0 0 1 0 1 1 1 1 1
0 0 1 1 0 0 0 0 0
0 1 0 0 0 0 0 0 1
etc etc
1 1 1 1 0 1 1 0 0
In this case I've put in the 5th output (F4) as a sign indicator, where 1 signifies the BCD value is negative. I've used 2s complement form to determine BCD for the negative excess-3 values.
A = MSB of input, D = LSB of input (Excess-3)
F4 = MSB of output, F0 = LSB of output (BCD)
From this truth table you can write up a K-map for each output F4 through F0. Simplest way is probably just get sum of products form for each output and do a quick AND/OR implementation for each output line, given the 4 inputs. If you want to simplify you can collect like terms as you desire.
If you don't know how to turn a K-map into a circuit you should probably revise that a lot. It's quite simple and you should do lots of practice to make it easy for yourself. It's too detailed for me to bother going into it here. Try your school library for a suitable textbook or just go to class more often.
EDIT: If either of my method or interpretation are wrong please excuse me! only in 1st year electrical eng course and it's late at night right now.
Wow you are smart hahaha...I'm just starting to understand this in class a little bit, but you seems to know what you talking about. I'm lost, but you guys have a lot of knowledge. I'm a noobie lol...Interesting.
Good luck! If you've just started the class don't worry it'll all soon make semse ;) good luck!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
