Using polar coordinates to determine the limit
rmiller70015
Lim (x, y)->(0,0)(X^3+y^3)/(x^2+y^2)
The answer is -1, but I can't get it there. Here is what I did.
((Rcosx)^3 +(rsinx)^3)/((rcosx)^2+(rsinx)^2)
Then by factoring out a r squared from top and bottom I'm left with a denominator of (sin^2(x ) + cos^2 (x)) which simplifies to 1. And a numerator of:
Rcos^3(x)+rsin^3 (x)
This is about as far as I've gotten and I can't figure out how to get it to a -1.
The answer is certainly not -1. The answer is 0 as ##r → 0##.
Conversely, if ##\epsilon > 0## is given, then choose ##\delta = \frac{\epsilon}{2}##.
The limit is not -1. If it were, the function should get closer and closer to it, when (x,y) gets closer and closer to (0,0). If you choose x=y, f(x,x)=x →0. If you choose x=rcosθ, y=rsinθ, f=r(cos3θ+sin3θ) which goes to 0 if r→0, for any value of θ.
ehild
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
