Using Separation of Variables to find potential inside of a sphere
mdwerner
A cubical box (sides of length a) consists of five metal plates, which are welded together and grounded (Fig 3.23). The top is made of a separate sheet of metal, insulated from the others, and held at a constant potential V0. Find the potential inside the box.
If \frac{1}{X} \frac{ d^{2} X}{dx^{2}} = Cx , then the solution is in an exponential form, otherwise is is in the trigonometric form.
Because in the X and Y directions the potential function must be zero twice, I decided that they must be of the trigonometric solution form. In the Z direction I chose it to have an exponential solution.
I decided that the boundary conditions were the following :
V(x,0,z) = 0
V(0,y,z) = 0
V(x,y,0) = 0
V(x,a,z) = 0
V(a,y,z) = 0
V(x,y,a) = V0
Applying these I decided that
X(x) = A sin [(n * π / a) x]
Y(y) = C sin [(m * π / a) y]
and
Z(z) = E e^{\sqrt{k^{2} + l^{2}} z} - E e^{-\sqrt{k^{2} + l^{2}} z}
However, I do not know where to go from here. I have not applied the last boundary condition that I listed, but I do not see how it would simplify the expression...are my boundary conditions correct? I don't see how I can solve any farther to find the coefficients A,C, and E.
Any advice on how to solve this things or criticism of my work will be much appreciated.
So you have a 3D PDE that is not too different from the 2D. You tell me, what are the boundary conditions?
Ah, okay, I see your edit now. The boundary conditions are fine. Try using cosh and sinh as the solution to Z(z). Exponentials are really only good if you are dealing with a boundary condition of infinity. Also, remember how the coefficients all relate to each other. :)
What do you mean "remember how all the coefficents relate to each other..." ? I am unaware of any relationship between the coefficients.
Also, I don't see how using the cosh helps -
My problem is that I don't understand how the last boundary condition that I listed can be applied. I already have expressions for the variables k and l (From the equations X and Y), so the only variable left when applying V(x,y,a) = V0 is the coefficient E. Is this correct? I have been reading other similar problems like this and I do not see any which solve to get EXACT values for the coefficients...EDIT : Actually, nevermind - the cosh does help, as it allows boundary condition 3 to cancel out the cosh term, leaving only the sinh term. Thanks for that bit of advice :)
Yeah, using cosh and sinh will let you get rid of the cosh from V(z=0)=0.
So back in the very beginning of the problem you would have had something that looked like this
\frac{1}{X}\frac{\partial^2 X}{\partial x^2} + \frac{1}{Y}\frac{\partial^2 Y}{\partial y^2} + \frac{1}{Z}\frac{\partial^2 Z}{\partial z^2}=0
and the only way for that equation to work out is if each individual piece is a constant. So you made
\frac{1}{X}\frac{\partial^2 X}{\partial x^2}=k_x^2
\frac{1}{Y}\frac{\partial^2 Y}{\partial y^2}=k_y^2
\frac{1}{Z}\frac{\partial^2 Z}{\partial z^2}=-k_z^2
Which gives the constraint that
k_x^2+k_y^2-k_z^2=0
So for your Z equation I imagine you are stuck here
Z(z)=A sinh(k_z z)
You know k_z in terms of the other constants k_x and k_y. You can get A from the boundary conditions.
Putting all that together you just use orthogonality in the end to determine the coefficients of n and m (griffiths calls them c_n and c_m respectively).
Hey how do we know which constant is neg or positive , where u have k2 does it matter ?
thxs
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
