How Does Variable Friction Affect Object Movement on an Inclined Plane?
In summary, the worker shoves the box up the plank so that it leaves the bottom of the plank moving at speed v0. When the box first comes to rest, it will remain at rest if v02>or=(3gsin2B)/(AcosB)
introphysics
A warehouse worker is shoving boxes up a rough plank inclined at an angle B above the horizontal. The plank is partially covered with ice, with more ice near the bottom of the plank than near the top, so that the coefficient of friction increases with the distance x along the plank : mu=Ax, where A is a positive constant and the bottom of the plank is at x=0. (For this plank, the coefficients of kinetic and static friction are equal: mu(k)=mu(s)=mu.) The worker shoves the box up the plank so that it leaves the bottom of the plank moving at speed v0. Show that when the box first comes to rest, it will remain at rest if v02>or=(3gsin2B)/(AcosB)
I drew a FBD and started the problem by solving for mgsinB = AxmgcosB. Basically that the friction was perfectly counteracted by that component of weight.
=> Ax=tanB
I don't know where to go from here. I didn't know if I should use kinematics or energy or what?
Hmm, well, I'm not sure your first step makes sense. If the box is moving up the plank, then wouldn't the || component of its weight and the friction force both be pointing in the same direction? So they wouldn't counteract each other. They would both work together as forces opposing the motion.
Edit: I see. You were talking about after the box comes to rest. Okay.
so I tried substituting for x according to the equation v2= v02 + 2a (x-x0). that gives:
v02= -2asinB/(AcosB)
then if I use ma=-mgsinB...
v02= 2gsin2B/AcosB
off by a factor of 3/2?
Here's one method. Although energy is not conserved, you can still keep track of things because you know exactly how much work is done by friction. Because the friction force is not constant, you have to integrate. If you don't know what integration is, and haven't done calculus, well then this could be difficult to understand. Maybe there is some other way of solving it. Here is what I did:
We want the height at which the box stops to be ≥ the height at which the box is in static equilibrium. The latter is easy: you have derived it
Height at which box is in static equilibrium: x = tanB / A
Height at which box stops = height at which all of initial kinetic energy is used up. I.e.:
initial kinetic energy = work done by friction + final potential energy
mv02 = ∫F(x)dx + mg xsinB (xsinB is the height of the box)
∫F(x)dx = ∫(AxmgcosB)dx = (A/2)x2mgcosB
Plugging the result of the integral back into the energy equation, we get:
v02 = (A/2)x2gcosB + gxsinB
plugging in x = (tanB)/A , because we want the energy to run out, at least at the height where static equilibrium occurs, so that the block stays there after it stops:
v02 ≥ (A/2)(sinB/AcosB)2gcosB + g(sinB/(cosB)A)sinB
When I simplify, I get
v02 ≥ 3g(sinB)2/2AcosB
That seems to differ from the result you were supposed to show by a factor of 1/2 though...:confused:
Sorry. This equation is only valid if the acceleration is constant. The acceleration is not constant, because the force is not constant. That's why I used integration in my previous post.
no that's right, it's just that the kinetic energy is 1/2mv^2thank you so much this actually makes sense! :D
LOL, yeah, good point!
You're welcome, and I'm glad it does.
1. What is variable friction proof?
Variable friction proof is a scientific concept that refers to the ability of a surface or material to change its level of friction, or resistance to motion, based on external factors such as pressure, temperature, or surface roughness.
2. How does variable friction proof work?
The exact mechanism of variable friction proof depends on the specific material or surface. In some cases, it may involve the release of lubricating substances or the rearrangement of surface molecules to reduce friction. Other materials may have specialized structures or coatings that allow them to change their friction properties in response to external stimuli.
3. What are the potential applications of variable friction proof?
Variable friction proof has many potential applications, particularly in industries such as transportation, manufacturing, and sports. It could be used to create more efficient and durable tires, reduce wear and tear on machinery, improve the performance of sporting equipment, and enhance the grip of surfaces in various environments.
4. Are there any drawbacks to using variable friction proof materials?
While variable friction proof materials have many potential benefits, there may also be some drawbacks to consider. For example, the cost of these specialized materials may be higher, and they may require more frequent maintenance or replacement. Additionally, the use of certain lubricants or coatings may have environmental impacts that need to be carefully managed.
5. How is variable friction proof being researched and developed?
The study of variable friction proof is an ongoing area of research in materials science and engineering. Scientists are exploring different methods and materials to achieve variable friction properties, as well as ways to optimize and control these properties for specific applications. This research may involve a combination of theoretical modeling, laboratory experiments, and real-world testing.
13K
