Varrying load distance applies a two equal forces on two roller
6 replies · 5K views
GarrettKoep
http://img198.imageshack.us/img198/374/20856431.jpg
Moment = R cross F
Couple moments?
I think I have to sum the moments from A, B and L all about C but I am not sure about the relationships between them.
Hi GarrettKoep! :smile:
Yes, that's right …
you know the directions of the forces at A B and L, but you have no idea which direction the force is at C, so the only sensible thing is to take moments about C. :wink:
And since the angular acceleration is (obviously!) zero, that means that the sum of the torques (moments) must be zero.
What do you get? :smile:
After summing the moments about C I calculated that b=27
(How did you get that? Anyway …)
erm :redface: … when I said "you have no idea which direction the force is at C", I thought that the "pawl" was rigidly fixed to the rest of the body.
But now that I've looked at the picture more carefully :rolleyes:, I realize that the pawl is loose … it can rotate freely at that unnamed point 8" up … let's call that point H.
And since the pawl isn't rotating, that means that the force at C must balance the force at H.
So we know the direction of both the forces at C and at H.
And the rigid body is supported by forces at A B L and H.
Use that information to find the direction and magnitude of the force at H, and then use moments to find b.
Sorry I missed that point earlier. :redface:
Okay, so if you calculated the sum of the moments about H the equation for b would change from (b-7)*L to (b-9)*L and they others would stay the same ( Fab *20). In conclusion, b would then be equal to 29.
If you want anyone to confirm that, you'll have to show your detailed calculations. :smile:
GarrettKoep: Your current answer is incorrect. Try again.
