Vector C & (A x B): True or False?
  • Thread starter Thread starter Chen
    Vector
Vector c is confirmed to be perpendicular to both vectors a and b. The expressions presented include various vector operations involving cross and dot products. Expression 1, (a x b) x c, results in a null vector, while expressions 2 and 4 yield scalar values with the same absolute value but differing signs. Expression 3, (a x c) x b, produces a vector. The discussion concludes that without further context, it is challenging to definitively confirm which expression is true.
Chen
It's given that vector c is perpendicular to both vectors a and b. Which of the following is true:
1) http://phstudy.technion.ac.il/~wn114071/physweb/question/1_4_01.gif
(a x b) x c
2) http://phstudy.technion.ac.il/~wn114071/physweb/question/1_4_02.gif
(a x c) dot b
3) http://phstudy.technion.ac.il/~wn114071/physweb/question/1_4_03.gif
(a x c) x b
4) http://phstudy.technion.ac.il/~wn114071/physweb/question/1_4_04.gif
(a x b) dot c
Can someone please just confirm the answer is (1) because I have only one attempt left at submitting an answer for this question.
Thanks :smile:
I can't open the files. You need authorization for that...
I knew that might happen, so I wrote the expression in each link below. (1) is (a x b) x c, i.e (a cross b) cross c.
Thanks.
It's impossible to say which one is true, because those are all expressions, not equations.
Answers 2 and 4 give you a scalar number. The absolute value is the same for both, but the sign changes.
Answer 1 gives you a null vector (all components equal to 0) since the cross product of A and B is either in the same direction as C or the exact opposite direction of C.
Answer 3 gives you a vector.
