Vector Cross Product Homework: Find 3rd Vector Perpendicular to C & D
To find a third vector perpendicular to vectors C and D, the cross product of C and D must be calculated. The user expresses confusion about performing the cross product without unit components, as they have encountered similar problems with given components. They clarify that the cross multiplication involves recognizing that the cross product of a vector with itself is zero. The final expression for the cross product simplifies to 2(AB) * BXA, confirming the user's understanding of the process. The discussion emphasizes the application of vector properties in cross multiplication.
xcgirl
C= B|A| + A|B|
D= A|B|-B|A|
C and D are orthogonal
Find a third vector perpendicular to both C and D
[AxB] = |A||B|sin(theta)
I know that to find the answer I need to find the cross product of C and D. I have done similar problems, but the unit components (i,j,k) have always been given. I can't figure out a way to do this without having those.
Thanks for any help, even a hint!
CXD = (B|A| + A|B|)X( A|B|-B|A|)
Do the cross multiplication of right hand side. Note that AXA = BXB = 0 And AXB = -BXA
You can multiply the magnitudes of A and B directly.
so I can do...
BxA|A||B| + BxB|A||A| + AxA|B||B| - AxB|B||A|
BxA|A||B| - AxB|B||A|
so would that be the final answer? thanks for the help, this all just seems a little weird to me. I didnt know that you could just essentially "foil" it like that
Last step
CXD = 2(AB)*BXA, because AXB = BXB = 0
thanks, you're a lifesaver! i totally get it now
