How Do You Formulate the Vector Equation for a Line Given a Point and Direction?
  • Thread starter Thread starter styxrihocc
    Line Vector
styxrihocc
Find the vector equation of a line that passes through the point (1,3,4) and is parallel to a line that passes through point (5,1,2)
<1,3,4> + t<5,1,2>
<1,3,4> + <5t,t,2t>
<1+5t,3+t,4+2t>
Is my answer correct? if not please point me to the right direction since I'm not quite sure how to solve this problem, thank you.
Is this the problem exactly as given to you? If so, you can't answer it because there are an infinite number of lines which pass through the point (5, 1, 2).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
