Vector evaluation & Lorentz force law
The discussion revolves around calculating the magnetic force on an electron in a magnetic field using the Lorentz force law. The magnetic field is given as B=2.0T(ex-ez) and the electron's velocity as v=(2.5x10^7 m/s)(ex-ey). A participant initially misjudged the sign of the ey term in their calculations, leading to confusion about the force's magnitude. After reevaluating the determinant, they confirmed the correct sign for the j term, realizing the mistake was simple yet frustrating. The discussion highlights the importance of careful vector evaluation in physics problems.
Roodles01
An electron in a magnetic field B=2.0T(ex-ez) has velocity v=(2.5x107 ms-1 (ex-ey)
a) calculate magnetic force on electron at that instant
b) what is the magnitude of this force
I am using the Lorentz force law.
F = q(vXB)
& evaluating the directions by vector
My argument is that the ey term is negative, but another person evaluates this as positive. Please confirm whether I'm right or wrong.
This affects the outcome of magnitude of force, too.
F = -e 2(2.5x107) (ex-ez)* (ex-ey)
I ex ey ez I
I 1 . -1 . 0 I
I 1 . 0 . -1 I
= ex((-1x-1)-(0x0)) + ey((1X-1)-(0x1)) + ez ((1x0)-(-1x1))
= ex - ey + ez)
so
F = -8x10-12 (ex - ey + ez)
Better believe your friend about the sign of the j term! (Re-check your determinant).
Ah! Having looked at it, I found that I didn't change the sign for the second term.
So simple it's annoying.
Thank you.
Welcome to the club! :smile:
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
