What is the vector function for the intersection of a cone and a plane?
Yae Miteo
"Find a vector function that represents the curve of intersection of the two surfaces."
Cone: z = \sqrt{x^2 + y^2} Plane: z = 1+y
I began by setting x=cos t, so that y = sin t and z = 1+sin t. At this point, however, I am stuck. I think I need to set something equal to something else, but I am not sure what.
[strike]You have 2 equations in 3 variables and you want to get 3 equations in 4 variables. This means you can only introduce one new equation where your new variable will appear. Otherwise you will have 4 equations in 4 variables and you no longer have the one degree of freedom required to get a curve. Here you have introduced two new arbitrary equations. Try just setting x = t and then try to express y and z in terms of just t.[/strike] Sorry, I thought you arbitrarily set y = sint, but it seems that you just made a calculation mistake (because you write "so that y = sint", which is wrong). It will be much easier if you just set x = t and then you solve y and z in terms of x (=t).
Do you have any particular reason for setting x= cos(t) and y= sin(t)?
Surely, not from the first equation?
If you set x= cos(t) and y= sin(t) then you are saying that z= \sqrt{sin^2(t)+ cos^2(t)}= 1 for all t- and that is NOT true.
The obvious thing to do, since z= \sqrt{x^2+ y^2} and z= 1+ y, is to set x+ y= \sqrt{x^2+ y^2}. Then, after squaring both sides, 1+ 2y+ y^2= x^2+ y^2 so that 2y= x^2- 1 and y= (1/2)x^2- (1/2).
Now, let x= t as the parameter.
Likes 1 person
Awesome! Thank-you.
Nevermind my previous post (deleted).
