Solving Vector Problem: Magnitude of R & r, Angle with x-axis
  • Thread starter Thread starter deaninator
    Vector
The discussion revolves around solving vector problems involving two vectors, r1 and r2, with given magnitudes and angles relative to the x-axis. The calculated magnitude of the resultant vector R (r1 + r2) is initially stated as 15.4, but later found to be incorrect, prompting a breakdown of the vectors into components for accurate calculations. The magnitude of the vector r (r2 - r1) is debated, with one participant correcting their earlier mistake to arrive at 4.66. The method of using the Pythagorean theorem and arctan to find angles is emphasized as crucial for solving these vector problems. Accurate component breakdown is necessary for determining both the magnitudes and angles correctly.
deaninator
Consider the two vectors r1 and r2 shown in the diagram. The magnitudes of the two vectors are: r1=6.1 and r2=9.3. The vectors directions relative to the x-axis are defined by the angles: θ1=25 degrees and θ2=51 degrees.
What is the magnitude of the vector R=r1+r2?
What is the magnitude of the vector r=r2−r1?
What is the angle between R and the x axis? (in degrees)
What is the angle between r and the x axis? (in degrees)
Picture is attached
For vector R, I think the magnitude is 15.4
For vector r, I think the magnitude is 3.2
But how do i figure out the other 2?
Thanks a million once again!
For the first question i also got 15.4, i got a different answer for the second question. The way that i solved this was i broke each vector into components, then i added or subtracted as indicated by the problem. For example to get 15.4 i broke r1 into x=5.53 and y=2.58, and I broke r2 into x=5.85 and y=7.23. I then added the x's and y's to get x=11.83 and y=9.81. I used these values to set up a triangle, and then used pythagorean theorem to solve R. Do the same thing for the second problem except subtract the components rather than adding them. I found the angles using the arctan of the opposite over the adjacent in each triangle. I hope this helps.
Ok 15.4 according to the computer is incorrect. Do you have to break down the vectors to components? Like my teacher assigned this problem but in class we never touched base on how to break down vectors.
Here are my solutions. Hope it helps!
Thanks it really did! But how did you get the magnitude of ''r'' to be 8.5? I keep getting 4.66
Oh yeah... you're right. I made a mistake punching the numbers in my calculator, so r = 4.66 Glad to have helped.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
